self etching or epoxy primer?
paint primer
3 replies to this topic
#1 Tat2Brat
Tat2Brat
    Advanced Member
  • PipPipPip
  • 49 posts
  • Tacoma WA
Posted 04 August 2014 - 06:26 PM
Gonna prime my 83 brat soon. The plan so far....
1) sand it and repair rust  (already done)
2) acetone it clean, possibly isopropyl alcohol after that
3) prime it!
4) body filler appropriate places
5) more primer
I was just gonna use the epoxy primers they have now a days cause they are pretty great
but then i was looking at my brat and sanding the rust off and thinking it would be great to have the acidic part of self etching primer
to get any of the surface rust that might be hiding in gaps or wherever (so hard to get it all)
can I body fill over the self etch?
or should i just stick to the epoxy?
I googled it of course but there is alot of different opinions out there thought i'd ask you knowledgeable folks
#2 KiwiGL
KiwiGL
    USMB is life!
  • 150 posts
  • Dunedin, NZ
Posted 04 August 2014 - 08:20 PM
If you're painting bare metal I'd recommend self-etching as it'll stick to the metal better due to the chemical reaction, but if you're priming over existing paint epoxy should be fine. Since you've sanded it back I'd go with the self-etching.
One thing though, it's not a rust-converting paint - so if you spray t over rust it won't stop the rust. It's just designed to etch new, clean metal.
Cheers.
#3 Carl B.
Carl B.
    USMB Regular
  • 129 posts
  • Colorado
Posted 04 August 2014 - 08:25 PM
^Exactly what KiwiGL said.
Cut out all the rust first and use etching primer on any bare shinny metal.
Look for a primer with zinc chromate, will be yellow to greenish color.
#4 stratman977
stratman977
    USMB is life!
  • 125 posts
  • Belle Vernon, PA
Posted 05 August 2014 - 06:50 AM
No body filler over self etching primer. It doesn't adhere properly and will never feather edge.
Also tagged with one or more of these keywords: paint, primer
