1996 Legacy Brighton transfer clutch solenoid check
i have purchased a used matching transmission for my 96 legacy because after driving it around with torque bind something in the transmission gave out. (i suspect it is the front diff, between the engine block and the transmission its self) My question is, is how can i check the resistance of the solenoid coil while i still have this transmission outside of the car. id like to know if it is faulty seeing as it is a used transmission, before i install it completely in the car. i am hoping someone knows what pins on the drivers side electrical connection plug is for the solenoid, and what the resistance should be. i really do not want to cut any of the protective outer jacket to trace out the wires on the connector. if i need to post pictures so people know what exactly i am talking about i can.
B raynor
