AC Bubbling
AC Cooling
2 replies to this topic
#1 garygrosso
garygrosso
    Newbie
  • Pip
  • 1 posts
  • Charlotte NC
Posted 14 August 2014 - 10:10 AM
I had to replace my engine on my 2003 legacy, (long story) The short version is never let anybody change your oil. When I go to recharge the AC the bubbling shown in the attached occures, What do I need to replace, Thank you.
#2 Rooster2
Rooster2
    Subaru Master
  • 4,728 posts
  • Indianapolis
Posted 14 August 2014 - 10:42 AM
Recently, I had to replace one of those metal tubing connections to what I think is called a dryer. My metal tube developed a pin hole leak. I suspect from seeing your photo, that you either have a bad "O" ring where the tube attaches, or your tubing leaks. Clean the area as best you can, so you can better see where the bubbles are coming from, and what needs to be replaced. Suspect your tubing got bent during motor swap to cause your leak. I sourced replacement tubing from a wrecking yard.
Replacement "O" rings can be bought from auto parts store. Think mine came from Autozone, sold in a plastic pack with assorted size "O" rings. O ring I took off at the fitting was black in color, what I installed was green in color. It fit well.......guess color doesn't make any difference.
#3 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,920 posts
  • Near Cortland NY
Posted 14 August 2014 - 04:19 PM
They are dirt cheap at subaru too.
Also tagged with one or more of these keywords: AC, Cooling
