Stevo F Posted August 20, 2014 Share Posted August 20, 2014 When going to charge my cell phone today I realized that the 12V lighter plug in our 2005 OBS doesn't work (tried 2 different working cell phone chargers). Never one of these go bad before- unlikely it's got its own fuse. Any other likely culprits or can you just buy another plug and wire it in? Quote Link to comment Share on other sites More sharing options...
987687 Posted August 20, 2014 Share Posted August 20, 2014 In my outback, power mirrors are the only other thing on that fuse. I'd start with checking the fuse... Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 20, 2014 Share Posted August 20, 2014 Check fuse first. Could have had a penny dropped in it at some point and blew the fuse. Quote Link to comment Share on other sites More sharing options...
tbolt1003 Posted August 20, 2014 Share Posted August 20, 2014 I had the same issue on my Impreza. Fuse was blown. Quote Link to comment Share on other sites More sharing options...
Stevo F Posted August 20, 2014 Author Share Posted August 20, 2014 Thank you all. I'll definitely check the fuse- hopefully that simple. Hasn't worked int he 6 months that we've the car, so maybe the PO did short it out somehow and never replaced the fuse. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 20, 2014 Share Posted August 20, 2014 well, there is a 'general' fuse but, on the back of the port itself, there is a fuse/overheat cut-out so, the fuse in the fuse block could be good and still have a dead port. Probably have to remove the port from the trim and replace it. Quote Link to comment Share on other sites More sharing options...
Stevo F Posted August 21, 2014 Author Share Posted August 21, 2014 Ugghhh... It was actually the phone charger after all. Did check the fuse and it was good. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 21, 2014 Share Posted August 21, 2014 I made a cheap light bulb tester for those sockets. It's a cheapo plug and a 194 wedge bulb socket from the auto parts store. Plug it in and if the light comes on then its getting power. If the light blinks or comes on when I wiggle the plug some the socket is cruddy and needs to be cleaned/replaced. 1 Quote Link to comment Share on other sites More sharing options...
