Way To Check Distributor From 84 Gl When It's Out?
11 replies to this topic
#1 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
  • Lake Tahoe Babieeeeee
Posted 23 August 2014 - 07:20 PM
84 gl fuel delivery problem. fuel pump was replaced and fuel pump relay also. I posted problem before here and it was suggested that the distributor was not sending signal to fuel pump .
so I took the distributor out and was going to switch out with my other 84 gl but it is not a match.
can the original distributor be repaired or checked out at a machine shop? or do I need to replace it?
it is breakerless but the wires that go into it is a different set up from the other GL. im cleaning all the grease off now so I can get the numbers off it.
#2 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 23 August 2014 - 07:37 PM
I think its a cardone. looks like the one I found on ebay.
#3 naru
naru
    1000+ Super USER!
  • 2,296 posts
  • under the bridge
Posted 24 August 2014 - 11:14 AM
Sure,but,it is easier with it installed.
As long as you have spark when cranking,the distributor is OK as far as the Fuel Pump Control Unit is concerned.
#4 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 24 August 2014 - 04:31 PM
thanks. it ran as long as I manually fed gas to the carb. the fuel pump is brand new as is the fuel pump relay. I was told here that the disty wasn't sending a signal to the pump relay to work the pump. even if the plugs were firing.
need more info.
#5 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,089 posts
  • South Prairie, Wa
Posted 24 August 2014 - 04:36 PM
There is a mod for the fpcu to turn the pump on when your key is in the run position.. you jumper the power in to the power out and run a new ground. turn the key if the pump comes on your in buisiness.  The trigger is now bypassed.
Mike
#6 jono
jono
    Reader and writer
  • 1,805 posts
  • Southern Hemisphere - AUS
Posted 24 August 2014 - 05:26 PM
don't believe it is a signal comes from the distributor either, more likely it is from the coil to the fuel pump control unit. An ideal replacement would be if available in the US would be a safety control switch device for propane fuel conversions and to be wired in separately. Has four wires genrally, power supply in, switched power out, earth, and a signal wire from neg side of the coil. power wire out would feed the fuel pump.
Edited by jono, 24 August 2014 - 05:27 PM.
#7 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 24 August 2014 - 07:22 PM
ok. been reading some old threads about this problem. if its not the dist. I could reinstall, switch the coil with a known good one. if that doesn't work I could also see if the screen in carb is clogged.
this car was a daily driver until this problem.  could I run a separate power line to pump to see if it is working? its brand new. so is the fpsu.
#8 Idasho
Idasho
    Lost in the woods....
  • 970 posts
  • North ID
Posted 24 August 2014 - 08:29 PM
IIRC, the fuel pump uses the same wire off of the coil that the tach does.
Yellow wire.
#9 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 25 August 2014 - 06:38 PM
checking wiring for fuel pump.
white  from fuel pump to blue with red stripe. black is ground.
found cut blue wire ( that comes out of body with blue/red ) that doesn't go anywhere.
is this a hot wire too?
#10 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 25 August 2014 - 09:50 PM
Different model, but this ideas Might help you:
~► http://www.ultimates...gnition-module/
Kind Regards.
#11 jono
jono
    Reader and writer
  • 1,805 posts
Posted 26 August 2014 - 04:04 AM
if the safety switch box in my Subies died off - I'd be replacing it with one of these
http://www.ebay.com....=item338a1b5a3e
so simple to hook up and has a little green LED for systems go I suppose.
#12 naru
naru
    1000+ Super USER!
  • 2,296 posts
  • under the bridge
Posted 26 August 2014 - 09:58 AM
Since it runs when spoon fed,both the coil and disty are plenty good enough to operate the FPCU.Forget about them.
A test light on coil - will flash w/cranking.
This same flashing signal needs to appear at the appropriate FPCU terminal.
A wiring problem may prevent this,Look for the flashes at the FPCU.
You can hot wire the pump for testing.
Check the ground too.
Change/check BOTH fuel filters.
