AKghandi Posted August 24, 2014 Share Posted August 24, 2014 (edited) 85 ea82 wag carb is there a cat in the y pipe, im pretty sure there is but i cannot remember.. anyways i want to gut mine if there is one anyone have any ideas on how to go about it? pretty sure its clogging up.. 220k and atleast three trips from ak to fl and back, according to car fax the floor is getting alot hotter than it used to and im losing power... also i do smell the bad cat rotten egg smell every now and then i already know how to gut the other cat, and its on my list Edited August 24, 2014 by AKghandi Quote Link to comment Share on other sites More sharing options...
czny Posted August 27, 2014 Share Posted August 27, 2014 "is there a cat in the y pipe, im pretty sure there is but i cannot remember.. anyways i want to gut mine if there is one anyone have any ideas on how to go about it?" Remove front Y-pipe from car. Cut rear pipe to get at catalyst bed. Drill thru with long twist drill bit, then punch thru remainder with a pipe & hammer. Empty out pieces. Weld rear pipe back in place. PM'd you about those new OEM pipes for the Y but you aren't interested it seems. Guess they'll go on fleabay now. Quote Link to comment Share on other sites More sharing options...
AKghandi Posted August 27, 2014 Author Share Posted August 27, 2014 yeah sorry I just cannot afford that right now. that method would work but i dont have a decent welder. Quote Link to comment Share on other sites More sharing options...
El Presidente Posted August 28, 2014 Share Posted August 28, 2014 You could probably use a coupler and some clamps instead of welding it. Josh Quote Link to comment Share on other sites More sharing options...
DaveT Posted August 29, 2014 Share Posted August 29, 2014 I cleared one by working through the O2 sensor hole, but it took longer. Quote Link to comment Share on other sites More sharing options...
