wallaby Posted August 26, 2014 Share Posted August 26, 2014 my offroad "utility vehicle" 82 Brat, previously...... engine fan was plugged into the pink connector near the battery(ig on power) ignition fuse under dash was replaced with a 20amp..(to deal with the extra power draw..) it stopped and would not restart, no spark. no power to coil, fuses good, fusible links etc good. after much troubleshooting i found i can jumper 12v to the coil and it will run i am guessing something got smoked but don't know where to look - wiring diagram??? can i just run a ignition on power to the coil( or into that pink conector....)or will that cause me other problems.... the coil runs on 12v right?? any idea of the current draw thinking if i do that , put a small fuse(3-5amp) in it then if there is any issue it will blow the fuse any info from the gurus? Quote Link to comment Share on other sites More sharing options...
lvsarge Posted August 26, 2014 Share Posted August 26, 2014 Wiring diagram: http://www.justanswer.com/uploads/JHoop/2008-04-30_113917_wiring_brat.pdf Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 27, 2014 Author Share Posted August 27, 2014 Thank you - will see if that makes any sense to me ..... Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 28, 2014 Author Share Posted August 28, 2014 in the interests of getting this thing going, i ran a wire from a random connector near the carb that has ignition power to the + side of the coil runs and everything works as it should for now... if i can keep it running for the next few months it will be going in for major work over the winter(trans, axles etc) hopefully can find the actual problem then...or maybe not.... Quote Link to comment Share on other sites More sharing options...
