Sawspa Posted August 27, 2014 Share Posted August 27, 2014 I can't figure out where the release for my rear hatch is on the inside of the vehicle. The manual says it is on a lever beside the gas lid release, but there isn't one there. Could the release be somewhere else? Can they be installed somewhere? Quote Link to comment Share on other sites More sharing options...
heartless Posted August 27, 2014 Share Posted August 27, 2014 if you look closely there should be two levers down there on the floor - the plastic handle(s) may be broken off making it difficult to see (mine was) - one lever is for the gas filler door, the second - closest to the door jamb - is the rear hatch release. Dont be surprised if it doesnt work - mine didnt. It is a cable operated system and on 25 year old cars they tend to be non-fuctional. cables break, latches get corroded and dont work properly, etc Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 28, 2014 Share Posted August 28, 2014 If it's a wagon there is no "inside release". if it's a sedan....it will be there next to the gas release. The plastic may have broken, so all you will see is a small metal bar that had the plastic tab on it. Quote Link to comment Share on other sites More sharing options...
Sawspa Posted August 29, 2014 Author Share Posted August 29, 2014 It's a wagon. I guess I'll make one. Sure makes it handy when car camping. Thanks Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted August 30, 2014 Share Posted August 30, 2014 (edited) Does the handle on the hatch itself not work? Edit: nvm, I just read the part about camping Edited August 30, 2014 by SubaruWagon87 Quote Link to comment Share on other sites More sharing options...
Sawspa Posted September 5, 2014 Author Share Posted September 5, 2014 I had to replace the outside handle too. It should be an easy to build, upgrade. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted September 9, 2014 Share Posted September 9, 2014 I would imagine that you would be able to get one of the glow in the dark emergency pull cables from a newer model car trunk (maybe find a front end damaged Subaru in a junkyard and go to town on its trunklid) You could then hopefully find a way to attach the cable to the existing mechanism in the hatch, drill a small hole and have the small pull handle sticking out into the cargo area on the inside of the hatch. Quote Link to comment Share on other sites More sharing options...
