Jumpinariver Posted August 28, 2014 Share Posted August 28, 2014 Recently bought a loyale with a 1991 ej engine. I'd like to install a/c but have no idea where to start on something like that. I'm not too savvy. Is there a kit? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 28, 2014 Share Posted August 28, 2014 Does the Loyale have A/C? or did it have it any parts left? Biggest obstacle is the high pressure side line. You must have a custom line made at an A/C shop. Use the Compressor end that matches the EJ compressor, and the body side that matches the Loyale body. Everything else is pretty much hook it up and charge it. The "pulse amplifier" will need to be replaced with a standard relay. Quote Link to comment Share on other sites More sharing options...
capn_r Posted August 28, 2014 Share Posted August 28, 2014 On the low side (larger) line I have used one from an early Impreza. It fit the evaporator end ( most EJ's are bigger) I did require using the matching Impreza compressor and mount bracket. Quote Link to comment Share on other sites More sharing options...
