Will 16" Impreza wheels fit on 2012 Outback
4 replies to this topic
#1 outback12
outback12
    Newbie
  • Pip
  • 1 posts
  • Syracuse, NY
Posted 01 September 2014 - 09:29 PM
I'm looking for wheels to put snow tires on 2012 outback,  I've located several sets of Impreza wheels (16"), which should fit based on diameter and bolt pattern.  the wheel offsets vary from 53-55, vs. 48 for outback.  Will they still work?
#2 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,033 posts
  • Grand Valley, PA
Posted 02 September 2014 - 12:11 PM
If they share the same bolt pattern you should have no trouble
#3 Gloyale
Gloyale
    It's a sickness
  • 10,546 posts
  • Corvallis, OR PNW
Posted 02 September 2014 - 12:26 PM
Brakes on front may be too large to fit with 16"
#4 gbhrps
gbhrps
    20 Year Subie Fan
  • 1,100 posts
  • Canada
Posted 03 September 2014 - 02:50 PM
outback12,
16 inch rims will fit your OBW. I have my snow tires mounted on the 16 inch steel rims that I used on my 2007 OBW, and kept for use on my present 2012 OBW. The 16 inchers put the speedometer out a wee bit, but with a GPS I was able to reconfigure in my head where I need to run the speedometer needle about 6 kmph faster at 50 mph or 80 kph.
Whichever wheels you go with, check them first on the front of your OBW, to ensure that they'll clear the rotors and calipers. If they fit on the front, they'll fit on the rear.
#5 heartless
heartless
    Do YOU Subaru?
  • 3,273 posts
  • North Central Wisconsin
Posted 04 September 2014 - 06:44 AM
it isnt the wheel that will change the odometer output, but the size of the tire mounted on that wheel.
if you want to get as close as possible, use this tool to figure it out: http://www.miata.net...e/tirecalc.html
put in your stock wheel/tire size on the left, and the new wheel/tire size you are considering on the right to see how far off your speedometer will be.
