wandersub Posted May 13, 2004 Share Posted May 13, 2004 I just found out I have a leaking valve cover gasket on my 2001 Forester. I would like to replace this myself if possible. I'm a fine mechanic with a Chilton's or Haynes at my side but, as I'm sure you know, that's not available for this car. I've got a pdf copy of all the service manuals available but so far have found them to be less then useful. I haven't found anything in there yet about replacing the valve cover gaskets. So a few questions: 1) Did I overlook it? Is there a section in the service manuals on replacing the valve cover gaskets? 2) Is it a hard job without experience or a manual? In other words can I fake my way through it? 3) Assuming I have to go at this without a manual, any tips, hints or suggestions that may help me along the way? Thanks in advance. Alan Quote Link to comment Share on other sites More sharing options...
theotherskip Posted May 14, 2004 Share Posted May 14, 2004 it is totally easy to replace. just a little tight. you will need new valve cover gaskets, bolt seals, and spark plug hole gaskets. brief instructions can be found in the "service procedure - valve rocker assembly" section. just follow the 1st step for removal and the last step for installation. in the 97 manual, it requires 3.6 ft-lbs of torque to retighten the bolts. otherwise it is very straightforward.... Quote Link to comment Share on other sites More sharing options...
