ivantruckman Posted September 2, 2014 Share Posted September 2, 2014 My running lights no longer come on with the headlights , If I turn on the parking light switch in the center of the steering column they work, all except the dash lights ? where is the problem more likely to be . ignition switch ? or perhaps the headlight switch . any help would be much appreciated, This is my DD and the daylight is getting shorter every day . Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 2, 2014 Share Posted September 2, 2014 The park lamp switch on the steering column is a different circuit than the headlight circuit. The headlights ground through the switch. Even when not on or not working, you will get voltage at the headlamp socket. Do you have an aftermarket stereo? At least you are not having the park lamps come on with the brake pedal (mine does this) Check the fuse links in the black box mounted on the overflow bottle, 2 green, one red, one black. Check your fuses. The fuse link can be replaced with 'J' fuses Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted September 2, 2014 Author Share Posted September 2, 2014 Hmmm just noticed that the left head light is dim . I will check all the grounds . and report back . Quote Link to comment Share on other sites More sharing options...
Gloyale Posted September 2, 2014 Share Posted September 2, 2014 (edited) Hmmm just noticed that the left head light is dim . I will check all the grounds . and report back . Left headlight Fuse or Relay is not working. Left is dim because it's backfeeding voltage from the right side. Also makes sense I think the left side /relay also power the Runnning light circuit. I'm guessing the relay cause it supplies both fuse 6 (lighting) and fuse 7 (LH headlights) It has a green connector up under dash group of four relays to left of steering column. Edited September 2, 2014 by Gloyale Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted September 2, 2014 Author Share Posted September 2, 2014 I just read Jezek's write up on the relays . That has to be it. 1 Quote Link to comment Share on other sites More sharing options...
