adalmat Posted September 4, 2014 Share Posted September 4, 2014 99 Forester L Am also having difficulty locating ABS diagnosis connector under-dash. Is connector plugged into another plug? Is plug white or black? Ground leads green wire? Can't even find lump in existing wiring. Five under-dash photos in link: http://postimg.org/gallery/m128x6vo/49002190/ Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 6, 2014 Share Posted September 6, 2014 It's a black connector. 6 pins. Pictured in the first picture in this thread: http://www.subaruoutback.org/forums/80-electrical-electronics/27938-lets-play-game-called-what-did-i-break-diagnostics.html The black plug. The two bare pins with black wires are the ground pins you need for the diagnostic. Look for the 9 pin yellow plug and the black plug should be nearby. These are usually more towards the center of the car. Between the column and the air control box behind the center console. Quote Link to comment Share on other sites More sharing options...
