Servicing Fuel Injectors
3 replies to this topic
#1 alia176
alia176
    USMB Regular
  • PipPipPip
  • 87 posts
  • NM
Posted 13 May 2004 - 01:19 PM
Hey guys,
I'd like to swap the #1 and #3 injectors with the #2 and #4 in the hopes of tracking down my #1 and #3 cyl misfire code. Are the O rings generic type of O rings or are they something special? I'm sure to rip one or two so I figured I'd call the local stealership to see if they have any. They quoted me $13/each :confused: Wow! I'll soak the injector tips in FI cleaner or something.
Ali
'95 Legacy
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 13 May 2004 - 04:11 PM
The injectors...at least on the ones I've worked on, aren't exactly the easiest to get out, however you should be able to get them out without damaging the o-rings. From my experience, generic ones don't seem to fit as well.
#3 Storm
Storm
    USMB is life!
  • 143 posts
  • NEOhio
Posted 13 May 2004 - 06:57 PM
I'd be looking at the coil ends of the plug wires. They are known to get corroded.
#4 legacy2.5
legacy2.5
    USMB Regular
  • PipPipPip
  • 109 posts
  • madison
Posted 13 May 2004 - 07:02 PM
i agree with storm, had that code before, it was the #3 coil wire
