Hitoshi Posted September 12, 2014 Share Posted September 12, 2014 Hey, I'm having trouble getting my weber installed without a vacuum leak between the manifold and the adapter as well as the adapter and the weber. Do you guys have any tips or methods for getting those installed without leaks? I've tried dry gaskets, "greased" gaskets as per the instructions. I think the best success I've ever had was using a cereal box gasket with some gasket sealant between intake/adapter I bought from the local auto store then a dry gasket for the adapter/Weber but even then I had some issues with it eventually. I've already broke a adapter torquing down the weber. And I'm not sure how much more I could get those alan bolts down without breaking it. This also applies to the carb studs/Weber nuts. Any tips or help would be appreciated! Thanks- Toshi Quote Link to comment Share on other sites More sharing options...
wagondragon Posted September 12, 2014 Share Posted September 12, 2014 Have you checked the flatness on your intake and the adapter plate? Quote Link to comment Share on other sites More sharing options...
spazomatic Posted September 12, 2014 Share Posted September 12, 2014 The weber i bought used wasnt exactly flat on the bottom, and neither was the adapter. The adapter i trued up with sandpaper taped to plate glass, and with the weber base i carefully went over it with a broad flat file. Both the adapter and carb really only need to be a snug fit, i cant remember the actual torque value....but if you're tightening them so much that you are worried about breakage, that may very well be part of the problem. Quote Link to comment Share on other sites More sharing options...
Hitoshi Posted September 12, 2014 Author Share Posted September 12, 2014 Okay, the surface seems like the next thing to check. Both the weber and adapter are brand new but I'll go through and check the all the surfaces. Also, do you just use dry gaskets or some sort of grease applied? Quote Link to comment Share on other sites More sharing options...
ferox Posted September 12, 2014 Share Posted September 12, 2014 I always use gasgacinch. It's made for sealing carbs and is gas resistant. I also cut my own base gaskets from high quality gasket material that can be found cheaply at any auto parts store. Just coat the gasket with the gasgacinch and let it dry. It's like rubber cement, so it doesn't take long to dry. I usually do two coats, works great. http://www.autozone.com/autozone/accessories/Edelbrock-4-oz-gasgacinch-gasket-sealer/_/N-25c6?itemIdentifier=214303_0_0_ http://www.gasgacinch.com/gasgacinch_002.htm 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 12, 2014 Share Posted September 12, 2014 In my Case, I've used Shellac, always with great results. Shellac is thick, also is Gasoline & Coolant Resistant, and doesn't need time to cure. ~► http://www.amazon.com/Permatex-20539-Indian-Shellac-Compound/dp/B0008KLOG6 Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
spazomatic Posted September 13, 2014 Share Posted September 13, 2014 Using a sealant on the gasket is fine, but if the surfaces are true, you do not need it. The only time I'll add some sort of sealant to a gasket is when there's a coolant crossover. And again, they do not need to be overly tight. Quote Link to comment Share on other sites More sharing options...
Hitoshi Posted September 17, 2014 Author Share Posted September 17, 2014 Hmm, I sanded down the surface of the manifold. I think it's a little better but there's still a leak at the base between the manifold and adapter piece. Maybe it's the gasket material I got from the autoshop isn't right but still leaking... I'll try it again with shellac now.. hopefully that'll do the trick. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 17, 2014 Share Posted September 17, 2014 That leak will never be Easy to Seal if Matching surfaces are Not flat, But I've had great Results in the past with Shellac in similar circumstances. ... I'll try it again with shellac now.. hopefully that'll do the trick. Don't forget to Smear both sides of the Gasket. Let us Know the Results. Kind Regards. Quote Link to comment Share on other sites More sharing options...
BirdMobile Posted September 17, 2014 Share Posted September 17, 2014 (edited) I personally did away with gaskets, and sealed directly metal-metal with Permatex #2 non-hardening fuel resistant sealant in between surfaces as the sealant. This eventually resulted in a vacuum leak as the sealant was pulled toward the intake. I re-sealed using Permatex on the inside near the intake port, and anaerobic sealant on the outside to keep gasses from pulling into the edge of the assembly. That seems to be working fine so far, I plan to disassemble it in a few weeks to see if any further "sealant creep" of the permatex non-hardening has occurred. One last thing - I sanded the adapter plate, intake surface, and weber base with a large machinists parallel and 240 grit wet/dry sand paper before doing all this - to achieve flat mating surfaces. Edited September 17, 2014 by BirdMobile Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 17, 2014 Share Posted September 17, 2014 I personally did away with gaskets, and sealed directly metal-metal with Permatex #2 non-hardening fuel resistant sealant in between surfaces as the sealant. ... In my Personal case, I sealed the intake / adapter on my Subaru "BumbleBeast" Using Aluminium Welding, as you can Read on my Weber Swap Writeup (Here) But I suggested Shellac, because not all the people want to do that as a Permanent Modification. The welding avoid the use of Gaskets ...and future vacuum leaks for Sure. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 27, 2014 Share Posted September 27, 2014 ... I'll try it again with shellac now.. hopefully that'll do the trick. Did you Tried Shellac there? Quote Link to comment Share on other sites More sharing options...
Hitoshi Posted October 17, 2014 Author Share Posted October 17, 2014 I'm hoping to get to it this weekend. Been really busy lately. I'll post an update when I do. 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 28, 2014 Share Posted October 28, 2014 So, any update? Quote Link to comment Share on other sites More sharing options...
Hitoshi Posted January 14, 2015 Author Share Posted January 14, 2015 I know this is months later but I finally did get around to using shellac. Unfortunately, I lost oil pressure when I was test driving and wasn't really in a place I could stop safely. Now it's all f-ed up.. Maybe I need a new hobby lol. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 14, 2015 Share Posted January 14, 2015 ... I lost oil pressure ... Why? What were the symptoms? Quote Link to comment Share on other sites More sharing options...
l75eya Posted January 15, 2015 Share Posted January 15, 2015 I know this is months later but I finally did get around to using shellac. Unfortunately, I lost oil pressure when I was test driving and wasn't really in a place I could stop safely. Now it's all f-ed up.. Maybe I need a new hobby lol. Wow.. You sure the car is messed up? Maybe the sending unit on the gauge just went kaput? That sucks man. Quote Link to comment Share on other sites More sharing options...
