Leaking Gear Oil
4 replies to this topic
#1 Guest_Vertigo_*
  • Guests
Posted 08 August 2003 - 02:38 PM
My car is an 88 Sedan GL and its 2wd 3AT and its leaking gear oil kinda bad like 3 to 4 drops when the engine is off and sits for a second. I'm thinking its the drain plug and I'm gonna replace it this weekend. but is there any other place gear oil can leak from?
#2 Guest_carfreak85_*
  • Guests
Posted 08 August 2003 - 02:45 PM
i doubt you have a bad "DRAIN PLUG" rather i think you are missing the crush washer that goes between the tranny case and the drain plug. just a thought, and you can probably get one at schucks or from subaru.
#3 Guest_todds_*
  • Guests
Posted 10 August 2003 - 12:40 AM
that motor is prone to leak oil through the head gasket area on bottom of the engine. theres a o ring problem from factory.every one i had leaked there. not much but enough to look crappy and get on exust pipe.and stink. thinking of a deflector of sorts. good luck todd
#4 Guest_todds_*
  • Guests
Posted 10 August 2003 - 12:44 AM
now i see ,gear oil well i uhh jumped the gun todd
#5 Guest_Vertigo_*
  • Guests
Posted 12 August 2003 - 09:06 AM
Ok I replaced it with one I got at checker but it wasn't a metal washer on it, it was actaully different but I didn't think it mattered. anyway It still leaks and it seems a bit worse now. Do I need to get a metal one or what? or is my tranny just messed up?
