Subarocket Posted September 28, 2014 Share Posted September 28, 2014 I've picked up some Tempo front springs and Accord rear springs for my 92 Loyale. I've got a lift kit and plan on cutting the accord sprigs so I'm not doubling up on the lift. When you cut the accord springs I've heard that you cut a coil and a half off to retain stock length. Do you cut off the bottom or the top? Do you have to worry about not having the full coil that sits flat? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted September 29, 2014 Share Posted September 29, 2014 I always cut the tops of the springs. With the Accord springs, you could also cut the top. I would rather have it seat flush in the perch of the strut. By the way, the accord springs sit perfect in the EA82 rear struts. I didn't cut mine, and now need to run a 5" kit in the front to make the car sit level (More lift the better!) -Tom Quote Link to comment Share on other sites More sharing options...
Ibreakstuff Posted September 29, 2014 Share Posted September 29, 2014 +1 always from the top, the top mount has a better fit for a cut spring. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 30, 2014 Share Posted September 30, 2014 ... Accord rear springs ... Something is Wrong here, you'll need Accord's FRONT springs for the Rear of your Loyale. Please review this Writeup for further details & Pics on such Modification: ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ ... the accord springs sit perfect in the EA82 rear struts. I didn't cut mine. ... Me Neither. Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
Subruise Posted September 30, 2014 Share Posted September 30, 2014 (edited) Something is Wrong here, you'll need Accord's FRONT springs for the Rear of your Loyale. Please review this Writeup for further details & Pics on such Modification: ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ Me Neither. Kind Regards. nor did I. I ended up using this setup + 2" rear lift for a total of 4" Edited September 30, 2014 by Subruise 1 Quote Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted September 30, 2014 Share Posted September 30, 2014 I never cut mine... my kit got biult arount the 2 inches over so I run a 6" out rear and a 7.5 up front.. rear sits a little higher thus eliminating sag w a load 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 30, 2014 Share Posted September 30, 2014 I never cut the Accord's front coil springs, when I used them along the original Subaru rear shock absorbers with flat base; Nor when I use them with the 4Runner shock absorbers with non-flat base; they work really Awesome like they are from factory. Kind Regards. Quote Link to comment Share on other sites More sharing options...
