HELP engine revs to 5000 after knock sensor replacement
SOLVED
I replaced my knock sensor by taking off the intake and then the throttle body since I have very big hands, and now when I turn it on the car goes to 5k rpm and stays there. Any ideas? I also relocated the knock sensor to a higher position as per suggestion somewhere on rs25, do you think that's the problem?
Edited by comatosellama
