So my 94 awd manual wouldn't start this morning because of the safety feature where the car won't start without the clutch pushed in. I turned the key twice with the clutch pushed in and all it did was click like it does when dead. I pumped the clutch a few times and it started right up... Any ideas? The clutch doesn't ever slip. Sometimes hard to get into gear but no grinding ever. Could someone also tell me how to remove that stupid safety feature so I don't get stranded from the car not starting lol.
Edited by PA Grown
First off when your neutral safety switch doesn't work
your car won't go click it just power on but nothing
when you go to start it
Anyway to remove your neutral safety switch All you need to do is
cut the wires that go to your clutch pedal at the top
and splice the two wires together
After that you can even leave your car in first gear
clutch out turn the key and it will roll and start
only time I recommend to do that is when
you're playing in the mud and you kind of get stuck
