TPaul Posted December 6, 2014 Share Posted December 6, 2014 My 1992 subaru loyale broke timing belt due to tensioner seizing. Belts replaced with marks on crankshaft pulley 180 or opposite with flywheel set at middle mark. Car would not start. Has spark and TDC and distributor seem fine. Has gas. Any suggestions? Quote Link to comment Share on other sites More sharing options...
moosens Posted December 6, 2014 Share Posted December 6, 2014 Are timing covers off now? Are marks still where they should be? Quote Link to comment Share on other sites More sharing options...
stratman977 Posted December 6, 2014 Share Posted December 6, 2014 (edited) I bet your'e 180 off on the timing, basically sparking on the exhaust stroke. try swapping the wires for the front two cyls and the back two on the distributor and see if it fires. Which cam did you set first when you changed the belt? Edited December 6, 2014 by stratman977 Quote Link to comment Share on other sites More sharing options...
mikaleda Posted December 6, 2014 Share Posted December 6, 2014 I'd double check timing marks Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 6, 2014 Share Posted December 6, 2014 rotate the crank again and then drop in the disty. The procedure requires 360 deg crank rotation between belts, and then again to find the #1 tdc just after the initial mark for the first belt Quote Link to comment Share on other sites More sharing options...
