mell0094 Posted December 18, 2014 Share Posted December 18, 2014 I have a VLSD rear diff from a early 90's Legacy ss (4.1 ratio, w/stub shafts) and would like to install into my 98 impreza. My Impreza has the male axle shafts on diff side. Can I swap to legacy axles or build a hybrid axle w/ lego inside cv joints attached to the impreza axles? Any help would be great Thanks, Pat Quote Link to comment Share on other sites More sharing options...
NorthCoast Posted December 18, 2014 Share Posted December 18, 2014 Imp trans is 3.9 so you would have to change the trans as well as the axles. No hybrid axle needed. Quote Link to comment Share on other sites More sharing options...
mell0094 Posted December 18, 2014 Author Share Posted December 18, 2014 Unfortunately my Imp is an auto w/ 4.1 gear ratio (checked build sheet through dealer, listed 4.1 gear ratio), so will I just need a set of lego rear axles? Any difference in length? p.s- thx for quick reply! Quote Link to comment Share on other sites More sharing options...
NorthCoast Posted December 18, 2014 Share Posted December 18, 2014 Just need the legacy axles that match the diff then. Length should be fine. Maybe a touch wider but not noticeable. Quote Link to comment Share on other sites More sharing options...
mell0094 Posted December 18, 2014 Author Share Posted December 18, 2014 You Da Man, thank you very much!! I kinda got stuck with this lego diff when I was sourcing a CLSD for my old loyale, very happy I can finally put it to use! Thanks again Quote Link to comment Share on other sites More sharing options...
mell0094 Posted January 5, 2015 Author Share Posted January 5, 2015 Well..... I went to do my rear diff swap, purchased the correct axles, double checked gear ratios and put the car up. Once the car was in the air I noticed my Impreza L has got the VA style rear diff : ( (like the brighton), can I swap the T-style diff in anyways? I researched it and it was saying something about it binding or being incorrect. And since I'm here- foolish of me but, are the input flanges the same on both diffs? I should have checked when it was up in the air.... Duh! Quote Link to comment Share on other sites More sharing options...
