legacy603 Posted December 27, 2014 Share Posted December 27, 2014 Well guys I'm losseing coolent and the heeds where done about a year ago I was thinking intake manifold gaskets if that doesn't fix it I'll do the block test buts its a small loss maybe 12 to 18oz every 200 or so miles any tips would be great thanks Quote Link to comment Share on other sites More sharing options...
mikaleda Posted December 27, 2014 Share Posted December 27, 2014 You could have the system pressure tested see if you can see any leaks in the system. I saw a pinhole leak in an upper rad hose on a Subaru once that caused a similar condition Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 27, 2014 Author Share Posted December 27, 2014 I thought the same thing but the only hoses that are not brand new are the heater core hoses Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 27, 2014 Share Posted December 27, 2014 These can often leak very slowly from the thermostat housing. Intake Manifold gaskets do not see any coolant on these engines. There is a coolant crossover pipe on top of the block beneath the manifold that has separate gaskets. Those can leak as well, but are not very common leak points. Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 27, 2014 Author Share Posted December 27, 2014 OK that makes sense is it possible that my heater core is going without leaking. My heat has started to go in and out but not a lot maybe for 30 seconds or so Quote Link to comment Share on other sites More sharing options...
keith3267 Posted December 27, 2014 Share Posted December 27, 2014 (edited) OK that makes sense is it possible that my heater core is going without leaking. My heat has started to go in and out but not a lot maybe for 30 seconds or so This would be a good starting point, but start with the hoses first. A leak at the end of a hose could appear to be a heater core leak, and since the hoses are a whole lot easier to replace than the core, that's where I would start. Then do the pressure test or do the pressure test first and look at the ends of the heater hoses for leaks. Edited December 27, 2014 by keith3267 Quote Link to comment Share on other sites More sharing options...
legacy603 Posted December 27, 2014 Author Share Posted December 27, 2014 OK thanks guys I'll let you know what I find Quote Link to comment Share on other sites More sharing options...
