Overheating/Radiator Plug Issue
Hello all, I have an 87 Subaru wagon gl non turbo. It started overheating and steaming and I found what looks like a drain plug mid way up the radiator. It clearly was the issue but when I tried to remove it the top just fell off. It clearly was sheared somehow or just broke. I can't find what the part name is. It doesn't make sense to be the drain for the radiator because its half way up on the left hand side, if facing the car. I've attached two pics of where it was and the severed top. Any help would be awesome on how to get the remaining piece out and what replacement I'll need. I have a Chilton and Haines and couldn't find it so far.
The piece https://www.dropbox.com/s/53qcvkwmjwuu6hi/2015-01-06%2014.28.56.jpg?dl=0
The spot it goes..if you zoom in you can see the white where it attached. https://www.dropbox.com/s/w0uv5lwrkezvu5h/2015-01-06%2014.19.01.jpg?dl=0
Edited by goldtoof
That is the plug hole for the thermister switch that tells the auxiliary fan when to go on and off.  Overheating may be because someone did not install that switch in so that your auxiliary fan never runs, unless it has been hot wired.  Overheating is also the symptom of cylinder head bolts getting loose enough for a cylinder head gasket to allow hot combustion air to be pushed into the cooling system.
Edited by scoobiedubie
