stripped ea82 with hitachi carb?
3 replies to this topic
#1 snowstormer
snowstormer
    Eat, Live, Breath Subaru
  • 272 posts
  • northwest wisconsin
Posted 18 May 2004 - 06:26 PM
is anyone running a fully stripped no emissions ea82 with a hitachi carb?
I want a motor with nothing on it except pcv system, disty vac line and manual choke.
I am wondering if a hitachi carb can be made to run smoothly on this motor if everything is plugged off.
also is it possible to remove and block off exhaust tubes, for lack of a better term?
any replies are welcome.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 18 May 2004 - 06:36 PM
Contrary to what most people think, there really is not any emmissions equipment on there that will reduce your power. The vacuum lines are largely for the evap system (to catch fuel vapors that evaporate on hot day with the car not running - eg: in a parking lot). The only real emmissions bit is the air injection system, which unlike a smog pump, does not use engine power. It runs from the exhaust pulses.
To answer your question, yes it can be done. You just have to know what each thing does, and why it's there. Once you know that it's easy to decide if it's ok to be removed or not. The Hitachi really doesn't have anything more than a Weber that it truely "needs" to run correctly - except the vacuum choke pull-off. The Hitachi is actually quite a good carb, and really not much different than a weber except for beign smaller, and having a vacuum secondary. The engine can be stripped down just like it can with a Weber.
None of this applies if you have a feedback carb - that's a different ball game.
#3 PoorManzImpreza
PoorManzImpreza
    Subaru Nut
  • 546 posts
  • BARBADOS
Posted 18 May 2004 - 06:58 PM
I'll tell you this my car came from Japan with ONLY PCV and Cat, but heh now it doesn't even have those..but then I'm in a different country;)
#4 Wasteland
Wasteland
    I am Evil Homer!
  • 412 posts
  • Western Slope
Posted 18 May 2004 - 09:36 PM
Do a search, there has been many posts on this subject. Theres a walk through out there some where that I posted a few months ago.
