fishernut Posted January 22, 2015 Share Posted January 22, 2015 99 forester S auto trans, 140,000 miles. Are the locks supposed to lock automatically when you start driving. Mine have locked but very seldom. Now, the locks lock at any ole time it feels like it and tries to lock over and over at random intervals. And, my FOB is not locking the doors after I park and get out. But it locks and tries to unlock (while driving) but does not unlock successfully. Right after the locks lock I hear what sounds like a vvaaccuumm sound, are the locks actuated by vvaaccuumm? There's no pattern to this behavior, not while braking or turning or going, not on bumps or smooth tar. Any ideas? Quote Link to comment Share on other sites More sharing options...
forester2002s Posted January 22, 2015 Share Posted January 22, 2015 What happens if you leave your remote at home? i.e. out of range of the car? Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 22, 2015 Author Share Posted January 22, 2015 I thought it might be the battery in fob, but issue happens fob just hanging in the ignition while driving. I feel like there's a short but where to start looking? tomorrow I'll leave fob at home and see what happens. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted January 22, 2015 Share Posted January 22, 2015 Remote has lost its program. Go to cars101.com and see remote section.to reprogram. Happens when you lose battery connection. O. Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 23, 2015 Author Share Posted January 23, 2015 I took the battery out and I still have the same results. Are the door locks supposed to lock automatically when the car is put into gear or hits/exceeds a certain mph? Going to cars101.com for ideas. Any one out there suspect that there's a short or a bad door button? Help. It's really annoying and I'm afraid I'll get locked out. My keyholes are crusted up and can't get the key in (like that when I bought it). Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 23, 2015 Author Share Posted January 23, 2015 So cars101.com tells me how to reset my remote. I do have the owner's manual and it reads identically. Since the battery is removed and I still have the issue, I need more suggestions. Thanks though, it's a cool site I've never been to. anyone? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 24, 2015 Share Posted January 24, 2015 Door lock timer is going bad. Kinda common. I don't know exactly where it is on the Forester. There may be some better help in google-land on the location. I recall there being an option for automatic locks on some of the later uears, bu I don't think that particular year would have that. If it doesn't say anything about it in the owners manual... Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 25, 2015 Author Share Posted January 25, 2015 Door lock timer? I'll dig into that and see what I can find. I assume the 1999 provide both manual and power locks, Both are covered in the owners manual. Now I've put a new battery in the fob but cant program it cuz the button is MIA and rest of the button is dangling under the dash. GRRR! Even with it un-reprogrammed, the locks continue to malfunction. Although it didn't do it for two days, it started again this morning. thanks Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 26, 2015 Share Posted January 26, 2015 I did a bit of googling myself and it seems people have good luck replacing or disassembling and cleaning the door lock switch. On the Legacys of that era the lock timer is behind the dash in the passenger corner. Roughly above/to the right of the blower motor. It's just a couple relays and an IC in a fancy plastic box. But when it goes bad causes this exact problem. I haven't found any info about location on a 99 forester (or if it even has it). Its usually a black box a little smaller than a credit car with a sticker on it that says "door lock timer" if you want to look around under the dash and try to spot it. Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 27, 2015 Author Share Posted January 27, 2015 I found this diagram on the web. item #15 in image. https://subaruparts.com/parts/1999/SUBARU/Forester/S?siteid=218240&vehicleid=724&diagram=7601250&diagramCallOut=15 Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 29, 2015 Author Share Posted January 29, 2015 FIXED Under the steering column, mounted on the dash panel is a small button used to program key fobs and something about valet key. This button must have gotten kicked or something but was broken, button was MIA and the switch was closed most of the time but open when it was bumped or jiggled causing the locks to malfunction. My people tell me that this button was Subaru OE but subbed out to an aftermarket company for installation. I wanted to replace it but was told that Subaru won't have one because of the previous statement and would be rare to find at a salvage yard. Easily purchased at Radio Shack, it's a basic momentary button. I opted to cut the plug off, tape the ends and tuck it under the dash. Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 29, 2015 Share Posted January 29, 2015 Any push to close switch will work. ACE or Radio shack will have them. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 29, 2015 Share Posted January 29, 2015 Good find! I wasn't aware that button would make the locks cycle. I've only ever dealt with those for disarming the alarm. Usually I just reconnect the battery with the key on so the horn doesn't blast. Quote Link to comment Share on other sites More sharing options...
fishernut Posted January 30, 2015 Author Share Posted January 30, 2015 I think I read that it has something to do the factory alarm but I do not have that. I won't replace the momentary switch cuz it may just get damaged again, When I need to program a fob I'll untape the ends and cross the wires til it's done. Quote Link to comment Share on other sites More sharing options...
