After steering wheel removal and replace, horn only works intermittently?
So after I cleaned everything up, and reinstalled the wheel, my horn doesn't respond like it used to. Before I took the wheel off, the horn would engage as soon as i pressed the horn button. And it wouldn't stop until I released the button. (It worked as it should)
Now I have to fidget with the button until the horn sort of works, then doesn't, then does again. Can someone explain to me how the horn works? I assume that bronze finger makes contact with the metal ring on the back side of the steering wheel. But I'm not sure where to look to see the issue.
  • 1 year later...
