do u need a puller??????
3 replies to this topic
#1 beachbum
    Subaru Fanatic!
  • 431 posts
  • st.pete,fl
Posted 19 May 2004 - 10:31 PM
ok im going to be starting this tomarrow but wanted to ask u now,do u need a puller to get the crankshaft pulley off a 1980 ea81? thnx in advance,.
#2 beachbum
    Subaru Fanatic!
  • 431 posts
  • st.pete,fl
Posted 19 May 2004 - 10:53 PM
thnx shadow i was hoping i wouldnt need to get a puller.:banana:
#3 Guest_taprackready_*
  • Guests
Posted 20 May 2004 - 11:45 AM
Little lesson I learned you may benefit from. My pulley was corroded on the crank shaft and I tried to use a puller. The pulley is made of powdered metal and broke as soon as I put any side pressure on it with the puller. So no, don't use a puller. A little WD-40 and patience if it won't come off easily will make all the difference.
#4 beachbum
    Subaru Fanatic!
  • 431 posts
  • st.pete,fl
Posted 20 May 2004 - 04:42 PM
thnx tap, and thnx again all u keep my roo humming:)
