soopsoop Posted March 2, 2015 Share Posted March 2, 2015 (edited) i have an 88 dl wagon an ea82 and found out the diode for the ign relay was bad bypassed it and found out the ign relay is bad also so something took both out and i noticed when i put the key in the ign it dings slowly but if i jiggle the key a bit the dinging speeds up. all my dash lights works,not sure about the gas gauge until i put gas into it it has read 1/4 of a tank for 1 yr now. the am /fm radio works but the numbers and letters are all wore off and i don't have an owners manual. retested the ign coil with a good meter and its ok not sure of the module but i was using dads expensive digital test meter(about 500 bucks) had to return it before he got back from lunch. fixed the wiring for the a/c fan now i just need a relay and maybe a switch,does the high speed go through the relay also or is it seperate,because i still have no fan unless i hook it up directly? Edited March 2, 2015 by soopsoop Quote Link to comment Share on other sites More sharing options...
