Maacm Posted May 21, 2004 Share Posted May 21, 2004 I replaced the battery in the remote today as per the owners manual. I re initialized the remote by pressing the "lock" button 6 times. Nothing worked. I then attempted to re-program the system and followed all the other directions (open & close door, 10 on/offs, etc - I even tried unplugging the battery first) but never got the horn to blow to enter programming mode, ergo can't get Alpine Keyless remote to operate or arm system? The red LED on the dash blinks as does the remotes LED when a button is depressed. Anyone have an idea what to try next? Quote Link to comment Share on other sites More sharing options...
Joe McMillan Posted May 21, 2004 Share Posted May 21, 2004 I just did this . You have to turn the key 10 time real fast .The book saids 15 seconds Thats not very much time to turn the key 10 times . The horn has to beep after 10 key turns or you won't be able to program it . Hope this helps . Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted May 21, 2004 Share Posted May 21, 2004 Or you can turn the key one time, and do it the old fashioned way... Quote Link to comment Share on other sites More sharing options...
NOMAD327 Posted May 21, 2004 Share Posted May 21, 2004 Pushing either button six times should have done it. The obvious question is if the battery could have been put in upside down. It's easy to flip those button batteries and they should fit equally well in right or wrong orientation. If it's not in right, the little red LED probably won't flash when you push either button Quote Link to comment Share on other sites More sharing options...
Martinjmpr Posted May 23, 2004 Share Posted May 23, 2004 I'll apologize in advance if this is a dumb question, but do you have both key fobs? B/c if you have both and one works, the other doesn't, could be the problem is with the key fob and not with the keyless entry system per se? Quote Link to comment Share on other sites More sharing options...
