soopsoop Posted March 16, 2015 Share Posted March 16, 2015 i have an 88 dl wagon with spfi how difficult is it to change to mpfi ? i have looked and must be doing somthing wrong because i can't find anything i am sure i would have to change the ecu and maybe the intake also,are the injectors in the head or in the intake the car doesn't run now so it is no problem to swap. it is going to be my winter car because my pickup has no traction in the ice and snow. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 17, 2015 Share Posted March 17, 2015 i have an 88 dl wagon with spfi how difficult is it to change to mpfi ? ... Believe me, is like to change the engine + wiring Harness and ECU ... and in such case, it is better idea to do an EJ engine Swap, in my own humble opinion. Why? ... The injector ports are in the Heads on the MPFi, So the Heads are Different, management is Different, etc... Maybe only the mere Block is equal... it Doesn't worth all the effort and costs. Kind Regards. Quote Link to comment Share on other sites More sharing options...
angerthis Posted March 17, 2015 Share Posted March 17, 2015 I agree I just pulled the multi port fuel injection engine out of my 86 rx as of right now I am in the middle of doing my own EJ swap the multi port fuel injection on a 1.8L doesn't give you that much more power as I change the block to a non turbo block and eliminated the turbo it was much more efficient but still not that much more power then the standard throttle body injection Quote Link to comment Share on other sites More sharing options...
DaveT Posted March 17, 2015 Share Posted March 17, 2015 These last 2 posts pretty much sum up what I remember seeing discussed about these sort of changes in the past. If you want the challenge of doing the mods, I understand that. If the desired result is more power, EJ will do that with more reliability, and it seems to me a similar amount of work. Quote Link to comment Share on other sites More sharing options...
soopsoop Posted March 20, 2015 Author Share Posted March 20, 2015 thanks that helps a lot. Quote Link to comment Share on other sites More sharing options...
soopsoop Posted May 24, 2015 Author Share Posted May 24, 2015 where do i find info on a ej swap Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 25, 2015 Share Posted May 25, 2015 The awesome guide written by Numbchux is your best bet, in my own humble opinion. You can download the .pdf file here: ~► http://www.ultimatesubaru.org/forum/topic/122276-the-bumble-beast/page-5?do=findComment&comment=1212255 Kind Regards. Quote Link to comment Share on other sites More sharing options...
Tom0 Posted May 25, 2015 Share Posted May 25, 2015 Numbchux's guide andhttps://www.google.com/search?q=ej+swap+site:ultimatesubaru.org&ie=utf-8&oe=utf-8&gws_rd=cr&ei=aaFiVcrGPIPUmgWmvYD4Aw Have pretty much been my go-tosCheers, Quote Link to comment Share on other sites More sharing options...
