Aluxes Posted March 18, 2015 Share Posted March 18, 2015 Im looking at an 02 WRX 2.0 engine for a 100.00. Guy says he pulled the engine cause #2 cylinder had real low comp. like 20 psi. He says it didnt smoke or knock and has about 163,000. Perhaps a stuck valve? Its a complete engine minus the intake manifold. Any opinions? Quote Link to comment Share on other sites More sharing options...
john in KY Posted March 18, 2015 Share Posted March 18, 2015 I'd suspect a burnt valve. 1 Quote Link to comment Share on other sites More sharing options...
Aluxes Posted March 18, 2015 Author Share Posted March 18, 2015 A burnt valve wouldnt cause any lower end damage? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 18, 2015 Share Posted March 18, 2015 Cracked ring land. Burned valve will usually make 0 compression. $100 is still good for a rebuildable block though. Quote Link to comment Share on other sites More sharing options...
Aluxes Posted March 18, 2015 Author Share Posted March 18, 2015 This is what Im thinking....I have a pair of 2.2 heads that are ported, new valves, springs, seals, phenolic spacers and Deltas. Will these heads bolt up to the 2.0 block? Id probably be running small boost sometime in the future. Is this a good idea, or no? What kind of problems might I be looking at? Mainly looking for a short block that I can rebuild and use my 2.2 heads and intake manifold with. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 18, 2015 Share Posted March 18, 2015 They'll bolt on just fine. If you have phase 1 heads get in touch with Cometic gaskets and have them make a 2.2 head gasket to match the heads, but with the proper bore size for the 2.0 bore. The normal head gaskets for the 2.0 will block coolant ports on the 2.2 heads. Quote Link to comment Share on other sites More sharing options...
Aluxes Posted March 18, 2015 Author Share Posted March 18, 2015 They'll bolt on just fine. If you have phase 1 heads get in touch with Cometic gaskets and have them make a 2.2 head gasket to match the heads, but with the proper bore size for the 2.0 bore. The normal head gaskets for the 2.0 will block coolant ports on the 2.2 heads. I have the 97 single port heads. These are phase 1 IIRC. So I would get HG's for this setup from Cometic? Just with the correct bore size. Quote Link to comment Share on other sites More sharing options...
Aluxes Posted March 31, 2015 Author Share Posted March 31, 2015 What kind of compression/power/torque would I get with this setup? Im currently using the ECU from a 97 2.5 to run the 2.2 that is in the car. Would I need to run the ECU for the 2.0 and would that plug in, or will I need a complete harness too? Quote Link to comment Share on other sites More sharing options...
