2.5 to 2.2 in 10 hours
11 replies to this topic
#1 lmdew
lmdew
    _______
  • 3,773 posts
  • Colorado Springs
Posted 21 May 2004 - 09:54 PM
**Update** 5/20/04 passed Colorado Emissions test without a problem. I've driven it a couple of hundred miles and the ECU showed no codes. I like the combination very much and for a $125.00 for a used engine you can't go wrong!
Just did a 2.5 to 2.2 swap on a 98 Legacy Outback. I'd picked up the 2.2 with 52K on it and then watched for a Outback that needed an engine. The swap went well (thanks CCR Inc. for the information). I only have to trace out the vac. lines, as there is one extra. Also will make some brackets for the power steering lines, as neither set will bolt up.
Anyone need a 2.5 as a spare?
Just pulled a 2.5 motor out of a 1998 Legacy Outback Wagon. It was missing on one cyc. The Shop thought it was a Head Gasket. Good Fixer, 109K was running fine other than the miss, when I pulled it. $550+shipping. Lmdew@hotmail.com
#2 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 22 May 2004 - 12:27 AM
Very Nice!!:banana:
I might consider a newer subaru if I could put in a nice 2.2 motor!!!
#3 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 22 May 2004 - 02:29 AM
Wow, Larry. Nice job.
#4 swami2806
swami2806
    USMB Regular
  • PipPipPip
  • 30 posts
  • Colchester CT
Posted 22 May 2004 - 02:07 PM
Larry..did the mounts line up, or did you have to mod.? what about bolting to the tranny?
#5 wrxsubaru
wrxsubaru
    1000+ Super USER!
  • 1,294 posts
  • Seattle Washington US
Posted 22 May 2004 - 03:55 PM
Subaru pretty univesal on trannie mating with engines. I would think the engine moutns would be the same sence its basicly almost the same engine. Just bored and stroked or what ever.
#6 lmdew
lmdew
    _______
  • 3,773 posts
  • Colorado Springs
Posted 22 May 2004 - 08:36 PM
Everything went right in. Just make sure you remove the top Trans support when you are going back in with the lower engine mounts. I left it connected to help support the trans while the engine was out and it held the lower engine mounts about an 1" fwd of the holes. Once I pulled the bolt, life was good.
#7 simpreza2
simpreza2
    USMB is life!
  • 232 posts
  • Hudson Valley NY
Posted 22 May 2004 - 10:04 PM
Hows the power and acceleration with the 2.2 in the outback? I might do this swap if my head gasket ever goes.
#8 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 23 May 2004 - 12:55 AM
be smog. Here in Ca smog can really be a pain unless the engine is newer than the car and has all the bits from the new engine. I had considered this as a possibility for my 99 Forester when the engine dies.
Perhaps things are a bit easier in Colorado.
I put a 289 in a Datsun Z yeatrs a go and built a Lotus 7 replica and both required many appointments and much patience to smog here.
This has cut my engine swapping way down.
#9 swami2806
swami2806
    USMB Regular
  • PipPipPip
  • 30 posts
  • Colchester CT
Posted 23 May 2004 - 08:39 AM
Things are easier EVERYWHERE than in the country of Cali. Get out of that god forsaken communist country while you still can. Barbara Fienstein should be dragged from the bumper of a V-12 SUV with no emmissions contols over a gravel road. Just my $.02.
#10 WagonsOnly
WagonsOnly
    Now only WagonsMostly.
  • 1,475 posts
  • North Central CT
Posted 23 May 2004 - 09:24 PM
That's Barbara Boxer (the other one is Diane Feinstein) and if you hadn't noticed the New England states are well on their way to adopting Cal-spec emissions. CT included, if they can come up with some decent test stations and incorruptible inspectors.
#11 rugbyben
rugbyben
    USMB is life!
  • 167 posts
  • State College, PA
Posted 24 May 2004 - 10:28 AM
Yah I live in PA, and they have adopted a "stricter" emissions test. Well not exactly stricter, just more expensive. now it costs $50 for the second sticker, and all they do is a visual inspection of the exaust, and a gas cap pressure test. funny, they used to do that on the regular safety inspection anyway... who does that $50 go to????
but seriously they are requiring the dyno test in the biger cities now too. luckily subarus are exempt because of the all wheel drive. ROCK ON!!! but you still have to pay for the visual test, but at least its one thing you dont have to worry about. bring on the fake CATs!!!
#12 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,359 posts
  • Columbus
Posted 13 June 2004 - 07:15 PM
every garage was forced to buy a new machine that is to be used for '96 and up. they cost thousands of dollars. the gas cap pressure test is much for unforgiving and instead of sticking a probe in the exhaust, it connects directly to the OBD2. But as far as i know, and i work at an inspection station, there's no minimum for emish tests, only a max of $100. don't quote me on the price though, i'm not certified.
