rxleone Posted April 21, 2015 Share Posted April 21, 2015 Hi all, back after a long stint away from old Subbies but have picked up an 88' EA82 wagon with 215k miles. It's a carbed model. Problem I have is the heater fogs up the windscreen when put on hot & defrost. Doesn't seem to clear more than half the windscreen after about ten minutes of running at operating temp. Is this normal or does it indicate more serious problems eg. coolant leaking in heater core? Nice to be back in an old Subaru again! Quote Link to comment Share on other sites More sharing options...
capmarvelous Posted April 21, 2015 Share Posted April 21, 2015 Does the heater work well in the car? And is the air blowing on the windshield hot? Quote Link to comment Share on other sites More sharing options...
rxleone Posted April 21, 2015 Author Share Posted April 21, 2015 Yeah, heaps of hot air coming out, all settings work correctly. Quote Link to comment Share on other sites More sharing options...
Leeroy Posted April 21, 2015 Share Posted April 21, 2015 If it is equipped with A/C you should turn this on too. A/C acts as a dehumidifier which means the windscreen will clear in no time. Quote Link to comment Share on other sites More sharing options...
citadel Posted April 21, 2015 Share Posted April 21, 2015 Could be your heater core has sprung a leak! Quote Link to comment Share on other sites More sharing options...
DaveT Posted April 21, 2015 Share Posted April 21, 2015 I have heard of pinhole leak in the heater core causing that, but there would be other symptoms. .. Check the fresh / recirculate air door. It is moved by vacuum. Quote Link to comment Share on other sites More sharing options...
john in KY Posted April 21, 2015 Share Posted April 21, 2015 Heater core is leaking. Quote Link to comment Share on other sites More sharing options...
classicxt Posted April 21, 2015 Share Posted April 21, 2015 I would have to agree on the heater core leaking............. Quote Link to comment Share on other sites More sharing options...
rxleone Posted April 22, 2015 Author Share Posted April 22, 2015 Thanks for the advice - where should I go now? I've never done a heater core replacement but am keen to try. Are they something you can buy aftermarket? Am I better off pulling a JY one? Quote Link to comment Share on other sites More sharing options...
somick Posted April 22, 2015 Share Posted April 22, 2015 I have had the same problem and the "stop leak" worked. Good luck, Sam Quote Link to comment Share on other sites More sharing options...
DaveT Posted April 22, 2015 Share Posted April 22, 2015 I have not had one fail, so I probably would lean towards used. It is a project, you have to remove the dash board to get to the heater box, remove it, and disassemble it to get to the core. Quote Link to comment Share on other sites More sharing options...
rxleone Posted April 23, 2015 Author Share Posted April 23, 2015 I have not had one fail, so I probably would lean towards used. It is a project, you have to remove the dash board to get to the heater box, remove it, and disassemble it to get to the core. Thanks Dave - I may ask a radiator shop and see if they can weld the hole. I've found a few instructions so will post back when I get a chance in the weekend to take out the dash. Cheers! Quote Link to comment Share on other sites More sharing options...
scubaroo84 Posted April 25, 2015 Share Posted April 25, 2015 Do you have the vacuum line for the heater box hooked up? If not that's probably your problem. The recirculation vent is normally open and vacuum holds it closed. Had this problem in my car on the mountain, always fogged up but would roast you out of the car. Turned out it was recirculating the interior air. Should be a vacuum hose on the passenger side going through the firewall. Quote Link to comment Share on other sites More sharing options...
Dee2 Posted April 26, 2015 Share Posted April 26, 2015 +1 on checking the vacuum line - same thing happened to me. Fixed the problem in 10 seconds. Quote Link to comment Share on other sites More sharing options...
