Gpef2.5xt Posted April 24, 2015 Share Posted April 24, 2015 Hey, new to this forum. A friend recommended I join (also a Subie freak). I have a 2006 outback xt and I keep getting cylinder 2 misfire code popping up when I beat the car up. If I'm driving normal it's ok. As soon as I get on it, check engine flashes and cruise control also flashes. At idle it trembles a bit also. I changed all 4 spark plugs (ngk iradium of course) and it's still doing it. Anybody have the same problem Quote Link to comment Share on other sites More sharing options...
nipper Posted April 24, 2015 Share Posted April 24, 2015 How many miles? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 24, 2015 Share Posted April 24, 2015 definitely check spark plug tubes for oil. Quote Link to comment Share on other sites More sharing options...
Gpef2.5xt Posted April 24, 2015 Author Share Posted April 24, 2015 154k miles. Changed the spark plugs and only cylinder 4 had slight oil. Cylinder 3 was the best one Quote Link to comment Share on other sites More sharing options...
Gpef2.5xt Posted April 24, 2015 Author Share Posted April 24, 2015 It's cylinder 2 that's misfiring. Thinking of swapping coil packs to see if that's the problem Quote Link to comment Share on other sites More sharing options...
wtdash Posted April 24, 2015 Share Posted April 24, 2015 Hi, Considering it's a high mileage Subaru turbo engine, you'll want to read up on NASIOC about the EJ255 (same as in the in '06-'14 WRX) and over on SubaruOutback.org. I'd recommend you get a compression and leak down test done, and if you're still on the original turbo, it's probably due for replacement. Make sure you check you oil EVERY time you fill up until you get this figure out or fixed. It could be burning oil but not blowing smoke. Td Quote Link to comment Share on other sites More sharing options...
Gpef2.5xt Posted April 28, 2015 Author Share Posted April 28, 2015 Thanx for the info. Me and my buddy will perform the compression test and leak down test. The turbo was replaced at 125k. I'll swap the coil packs to check them also Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 28, 2015 Share Posted April 28, 2015 My money is on the injector. It's not uncommon for the o-rings to deteriorate on them. In normal conditions, it wouldn't be normal, but could very well be deficient under load. ps: If you want that engine to last, don't "beat up" on it. Be uber careful about oil changes and coolant too. It's a turbo, yes. But it's not a freaking race car. Quote Link to comment Share on other sites More sharing options...
