Joe McMillan Posted May 23, 2004 Share Posted May 23, 2004 Can anyone tell me the part numbers for NGK Plugs KN Filter Oil Filter Can I use synthetic oil ? I have a 2.5 engine Quote Link to comment Share on other sites More sharing options...
mattocs Posted May 24, 2004 Share Posted May 24, 2004 Its on the NGK site...but here it is: 2000 SUBARU LEGACY OUTBACK 2.5 H4 EJ25D2 EFI DOHC Spark Plug Part No. Stock No. Plug Gap Standard BKR6ES-11 5553 .044 V-Power BKR6E-11 2756 .044 G-Power Platinum BKR6EGP 7092 .044 Laser Platinum PFR6B-11 * 4014 .044 OE Laser Iridium IFR6E11 ^ 6741 .044 Iridium IX BKR6EIX-11 3764 .044 K&N air filter website says 33-2154 is the part number for that. Oil filters...well, the Subaru OEM ones are just Puralator...and they are cheap and decent filters. The PureONE filters are PL14460 and the regular ones are L14460. Sure, use synthetic oil. Do a search for it on the board. Some say different things...some pros and cons. Check it out. Quote Link to comment Share on other sites More sharing options...
wrxsubaru Posted May 24, 2004 Share Posted May 24, 2004 I would suggest using Synthetic it may leak a little more but it last longer and has higher resistance to heat. You have to rember the K&n dont seem to fitler that well. You could just put in a STi one there about $70 but i would trust it alot more than i would a K&n probley filters better and flows around the same amount of air. http://www.subaruparts.com/catalog/?section=405 Quote Link to comment Share on other sites More sharing options...
Chip Hedrick Posted May 24, 2004 Share Posted May 24, 2004 It's a load of crap to say that K&N filters don't filter well. I've had one in my '98 OBW for 30,000 mi. with no problems. The intake system is filthy before the filter and clean after it. I live on a dirt road to boot. Quote Link to comment Share on other sites More sharing options...
rweddy Posted May 24, 2004 Share Posted May 24, 2004 It's a load of crap to say that K&N filters don't filter well. I've had one in my '98 OBW for 30,000 mi. with no problems. The intake system is filthy before the filter and clean after it. I live on a dirt road to boot. Just so many there are many sites that state that this is true, for the very little increase in airflow that K&N's afford they also allow much larger particles to enter the engine. If you have a Cummins Diesel Motor (Ram Truck) it voids the 100,000 mile warranty if you use one. I personally do not think it is worth the cost and larger particles entering the engine, IMO. Quote Link to comment Share on other sites More sharing options...
Joe McMillan Posted May 24, 2004 Author Share Posted May 24, 2004 Thank you all ,for the info . Joe Quote Link to comment Share on other sites More sharing options...
myles Posted May 24, 2004 Share Posted May 24, 2004 Can someone post results from dyno. runs with stock and K&N air filters? I'd like to see the difference. Quote Link to comment Share on other sites More sharing options...
