ragingbull Posted May 5, 2015 Share Posted May 5, 2015 It broke at the weld on normal driving. I can re weld or does anyone recommend anything else? Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 5, 2015 Share Posted May 5, 2015 It broke from the bad angle it was put at because of the lift and not being modded to accommodate the difference in geometry. 1 Quote Link to comment Share on other sites More sharing options...
coxy Posted May 5, 2015 Share Posted May 5, 2015 Weld some reinforcedd channel section on the longer part mounted to the body and then replace the shorter part that goes through the rubbers with a Rod end and bolt the U bracket through the rod end with spacers allowing it torotate while still acting as a stopper. That will never fail again if done properly and it's not that big of a fabrication job. Quote Link to comment Share on other sites More sharing options...
ragingbull Posted May 5, 2015 Author Share Posted May 5, 2015 Sounds good! Thanks gents! Quote Link to comment Share on other sites More sharing options...
