Pierobon Posted May 14, 2015 Share Posted May 14, 2015 So, straight down to issue: I have a 2008 Outback with original Keyless system installed and Push-To-Start button. This also means that my car does not have a key slot in the steering wheel column. (click for pictures) When I bought it used, the previous owner only had one key.So, I bought a new original Subaru one, but the dealers here in Brasil are charging more than a thousand of my brazilian bucks (read U$350) just to program the new key into the ECU. (New single key is about U$1000). That's just too insane for me. So I bought the OBD-USB cable and tried to do the programming myself, but all I could do so far was reading the sensors of the car with FreeSSM. Because my car doesn't have the key slot to start the engine, I am not able to follow the key programming procedures found on youtube, because all of them involve turning the key on-off to activate the programming mode on the car. I also tried the original Service Manual way, but I just couldn't find the step 2 registration connectors (1 pole white). The Service Manual, Body section, page SL-47 describes: D: REPLACEMENT 1. REGISTRATION OF KEYLESS TRANS-MITTER NOTE:• A maximum of four keyless transmitter can be registered for each individual vehicle. • When replacing or adding the keyless transmit- ter, new registration of keyless transmitter is neces-sary. • When replacing the keyless transmitter,registra-tion to immobilizer system is also necessary. 1) Remove the keyless transmitter from the ignition switch. 2) Remove the lower trim cover at driver’s side,then connect the registration connectors. (1 polewhite connector) 3) Press the door lock switch (1) located under thepower window main switch to UNLOCK. (Makesure the room light blinks and buzzer sounds, andthen system is in registration mode.) 4) While pressing the button of keyless transmitterto be registered twice with door lock switch pressedto UNLOCK. (Button for LOCK, UNLOCK andTRUNK are acceptable) 5) When the registration is completed normally, thedoor lock actuator will lock → unlock. If the lock →unlock operation is not carried out, repeat the pro-cedure 4). NOTE: • When pressing the keyless transmitter button,slowly press for first and second (press longer forsecond) to check operation of door lock actuator.• Do not press the button of keyless transmittermore than twice. • Do not batter the button of keyless transmitter. 6) Repeat the steps 4) if there is an additional key-less transmitter to be registered. 7) Pull out the registration connector, and install thelower trim cover at driver’s side. NOTE: • The transmitter can be registered only when thedoor lock switch is remain pushed to UNLOCK.• Continuing to press the door lock switch to UN-LOCK again allows to be registered although thedoor lock switch is released for once. • When adding the keyless transmitter, re-registra-tion of keyless transmitter which was already regis-tered is necessary. 2. CLEAR OF KEYLESS TRANSMITTER 1) Remove the keyless transmitter from ignitionswitch. 2) Remove the lower trim cover at driver’s side,then connect the registration connectors. (1 polewhite connector) 3) Press the door lock switch located under thepower window main switch to LOCK. (Make surethe room light blinks and buzzer sounds, and sys-tem becomes in clear mode.) 4) While pressing door lock switch to LOCK, insertand remove the key on ignition switch 10 timeswithin 10 seconds. 5) When the clearing is completed normally, thedoor lock actuator will lock → unlock. If the lock →unlock operation is not carried out, repeat the pro-cedure 4). 6) Pull out the registration connector, and install thelower trim cover at driver’s side. NOTE: • The transmitter can be cleared only when thedoor lock switch is remain pushed to LOCK.• ContinuingtopressthedoorlockswitchtoLOCKagain allows to be cleared although the door lockswitch is released for once. • If changing from registration mode to clear mode,you cannot go to clear mode unless completing theregistration mode. The reverse case is same asthis. Solutions to my problem: 1 - There could be a different procedure to program my new key, pushing buttons and connecting cables, that doesn't involve OBD interfacing. 2 - There could be a computer software with the same function as those OBD Key Programmers devices, that I can use with a basic OBD-USB cable. Please please please help! Thanks a LOT! Quote Link to comment Share on other sites More sharing options...
djmark7 Posted May 14, 2015 Share Posted May 14, 2015 this? http://www.cars101.com/subaru/keyless.html#code Quote Link to comment Share on other sites More sharing options...
Pierobon Posted May 15, 2015 Author Share Posted May 15, 2015 Have you read my post? Seen my pictures (clickable links)? My key is not on the list from your link. Thanks anyways. =) Quote Link to comment Share on other sites More sharing options...
