Looking for someone with knowledge of 87 gl cruise control
1987 subaru GL, standard 5 speed ea82 spfi. I purchased the car about a month and a half ago. Has cruise control.
Problem is cruise control doesn't work. Car also starts without clutch pushed down. I am assuming this may be the reason cruise does not work as I would think cruise would shut off with clutch pressed down. Not sure though as cruise didn't work when I purchased the car.
I have looked at the clutch switch and have not had time to test it yet, but it does seem to click when I press it in manually, and clutch pedal does seem to make contact with the switch as it it supposed to.
I have also checked the fuse linked to the cruise. Fuse is good.
I am hoping someone with some knowledge of the way the cruise system works can chime in. Thanks
