Nowhereman Posted June 6, 2015 Share Posted June 6, 2015 I have a 1985 gl leone 1.8 turbo FI. My timing belt broke. I replaced timing belt and now there is no fuel getting to the plugs,there is fuel getting passed the filter in the engine compartment. I sprayed starting fluid in the air intake and it started kicking. so my question is what would stop the gas from getting to the plugs. everything was fine until the timing belt problem. Quote Link to comment Share on other sites More sharing options...
coxy Posted June 7, 2015 Share Posted June 7, 2015 Ignition Signal is needed to trigger Fuel Injectors, The distributor is driven off the camshaft make sure it is timed correctly and there is a tool called a "Noid Lite" that plugs into the Injector plug basically an LED in a fancy plastic housing if you are getting a signal to the Injectors it glows and pulses they are neither expensive nor hard to make and will make sure you have a trigger signal to the actual Injectors, Otherwise No fuel no Run. Quote Link to comment Share on other sites More sharing options...
