Skylar Posted June 7, 2015 Share Posted June 7, 2015 Having some trouble tracking down the issue as to why my passenger window is not working. I've got two regulators with motors that both work, tested them directly from the battery. I've got constant 12v from the white wire that goes to the relay, which is what I'm supposed to have according to an older post on here, what I DONT have is any power from the two bullet connection that plugs into the window motor. I swapped out the switch itself, still nothing. I loosened the screw for the grounds under the passenger seat and wiggled them around making.contact, relays were clicking so that means grounds are ok correct? My drivers window works fine, passenger window isn't operable from the drivers side switch either. Stumped at this point, checked my fuses. None are blown, I suspect this thing has power door locks but those aren't working either.. Quote Link to comment Share on other sites More sharing options...
wagonist Posted June 9, 2015 Share Posted June 9, 2015 The terminals in the switches get "corroded" over the years. You need to pull them apart & clean the contacts. Be careful undoing the screws though, the plastic gets brittle over the years. And for the passenger side to work, you need to ensure that both that switch & the master switch are clean. The power comes though both in series. Considering your master switch doesn't work, I'd start with cleaning that one. I've heard a rumour that the 2 doors never got power locks, but can't confirm that. 1 Quote Link to comment Share on other sites More sharing options...
Skylar Posted June 10, 2015 Author Share Posted June 10, 2015 Okay I'll clean the contacts inside and see what that does for me. Thanks. Quote Link to comment Share on other sites More sharing options...
wagonist Posted June 10, 2015 Share Posted June 10, 2015 I think there's a write up on here somewhere. A search should show it up. Quote Link to comment Share on other sites More sharing options...
Skylar Posted June 10, 2015 Author Share Posted June 10, 2015 Did some digging, looks like somewhere was in there cutting wires. Connected the white to the white and two blues to a blue and all is well. 1 Quote Link to comment Share on other sites More sharing options...
-tombba- Posted June 10, 2015 Share Posted June 10, 2015 I've heard a rumour that the 2 doors never got power locks, but can't confirm that. If you mean the third gen 2 doord cars I do have center locking in my -88 coupe. Basicly every GL and up versions have them in here. Quote Link to comment Share on other sites More sharing options...
