325turbo Posted June 8, 2015 Share Posted June 8, 2015 I'm planning to replace left outer front cv joint as it is rattling when driving and turning. Very traditional phenomenon. There seem to be different information about the spline counts. The outmost (hub side) spline count is 27, that is pretty sure. but the inner side (connection to axle) spline count has some variations. Some sources say 22, some 30. Any possibilities to be sure without disassembling the joint first? The local subaru dealer would know, but their prices surely are above my limits. The car is -95 Legacy GX Sedan, 2.2 AWD, manual transmission. Thx in advance! Quote Link to comment Share on other sites More sharing options...
325turbo Posted June 8, 2015 Author Share Posted June 8, 2015 (edited) Oops! Triple for some reason... Edited June 8, 2015 by 325turbo Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 8, 2015 Share Posted June 8, 2015 (edited) it will not be 22 or 30. It will be a an odd number like 23. and you MUST NOT get the spring pin hole 180 out of phase when assembling. I hope someone replies with specific numbers for you. Edited June 8, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 8, 2015 Share Posted June 8, 2015 That car will be 25 splines on the cv to trans side. Quote Link to comment Share on other sites More sharing options...
325turbo Posted June 8, 2015 Author Share Posted June 8, 2015 Pretty confused now... For example, this is described to fit (22 splines): http://www.ebay.com/itm/Outboard-CV-Joint-for-1990-96-Subaru-Legacy-/181745518231?pt=LH_DefaultDomain_2&hash=item2a50e08697&vxp=mtr This is also described to fit (30 splines) http://www.ebay.com/itm/ADS78912-SUBARU-LEGACY-1994-99-2-2i-Sal-GX-BD7-94-97-4x4-LH-Outer-CV-Joint-Kit-/301258841566?pt=LH_DefaultDomain_3&hash=item46246d1dde In fact I haven't found any joint with 25 splines... Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 8, 2015 Share Posted June 8, 2015 (edited) AH - OK, I do not know the axle-shaft's spline count. (could there be a difference between 2.5 H4 and the 3.0 H6 cars?) (I thought the issue was the green 'cup' for the tripod/DOJ joint's connection to the stub in the diff) sorry. Edited June 8, 2015 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 8, 2015 Share Posted June 8, 2015 looking at RockAuto.com, it appears you could have either on a manual trans - the auto only shows as 22. if you cut the boot off, you might find there's enough showing on the shaft to count. Quote Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted June 10, 2015 Share Posted June 10, 2015 25 spline it looks like for the inner shaft (NOT THE STUB SHAFT-TO-DIFF SPLINE COUNT). Used to be the 23/25 issue with the older non-turbo vs. auto. turbo manuals. But the AWD TY75 trans, should be 25. Quote Link to comment Share on other sites More sharing options...
325turbo Posted June 23, 2015 Author Share Posted June 23, 2015 (edited) Ok. Changed the joint today. Correct answer is 30 teeth. Still I don't have any idea what makes the difference. Anyway I ordered a new joint hoping it would fit. Luckily the teeth count was the same. But, the new joint is 8mm longer than the old one... I hope it won't make any harm... Edited June 23, 2015 by 325turbo Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 23, 2015 Share Posted June 23, 2015 I'm no expert but, IF (that's a big if) the actual - uh - centerpoint - for the articulation is the same, it might work. but, if that point is in a different position than the design requires, there's gonna be a fight with the spindle/knuckle/strut/control arms everytime it turns - (I THINK) Quote Link to comment Share on other sites More sharing options...
325turbo Posted July 3, 2015 Author Share Posted July 3, 2015 I changed today also the right joint. Easy job This new joint also was 8mm longer than the old one. I measured the whole axle length with the old joint and with the new joint installed. No difference within measuring accuracy. So, I guess there will be no problems. Quote Link to comment Share on other sites More sharing options...
