ThosL Posted June 13, 2015 Share Posted June 13, 2015 This was a shock to me, was driving on the highway, car was running smoothly then I noticed the temperature gauge was inching up toward danger zone. I could hear a hissing sound coming from the middle of the engine; I stopped at an auto parts place they were clueless. From what I have learned water leaks seem to be confined to the radiator and hoses going to and from the engine. Are there any smaller water lines around the engine? I am driving the vehicle back in 7 or so mile stretches as I was 70 miles away from residence when the problem occurred. No fun to have to continually pull over and re fill the radiator and have the steam coming out of the other side as I removed the rubber screw from the other top side of the radiator. Quote Link to comment Share on other sites More sharing options...
lstevens76 Posted June 13, 2015 Share Posted June 13, 2015 Ok. You have heater hoses behind the engine then you have coolant lines running through the intake. Are you losing the water onto the block or out of the reservoir? Quote Link to comment Share on other sites More sharing options...
ThosL Posted June 13, 2015 Author Share Posted June 13, 2015 The water was hissing on to the engine, like the leak was hitting the engine, and I saw the dripping directly down from the back of the engine. Quote Link to comment Share on other sites More sharing options...
vasy Posted June 13, 2015 Share Posted June 13, 2015 There are 1 or 2 small coolant hoses under the throttle body, about the thickness of a finger. 2 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 13, 2015 Share Posted June 13, 2015 Could be a split hose going to the throttle body as vasy said, or a crack or hole rusted in the metal bypass tube that runs along the top of the block on the drivers side. The heater return hose connects to it at the back. Removing the big air box on the throttle body can give you more room to see in that area. Could also be a split in the o-ring for the crossover pipe under the manifold. Quote Link to comment Share on other sites More sharing options...
ThosL Posted June 13, 2015 Author Share Posted June 13, 2015 (edited) Thanks a lot for the probable causes. I will limp back to my parking space later and then see if I can find a mechanic to fix it then. I guess it doesn't take much to turn a great running vehicle into a cripple. 2.2 '96 engine in 99 Outback Legacy. So really few options as no one is going to help you fix something like this that makes the vehicle, undriveable, and I don't know any other vehicle that is as prone to engine threatening problems as the old generation Subarus. I just hope the head gasket is not blown. I either had to call AAA to have the vehicle towed, which would easily run into the hundreds or be at the mercy of one of their recommended mechanics and have to find my way back 70 miles away or take my chances with my own attempts to keep the engine in the safe range. Edited June 14, 2015 by ThosL Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 14, 2015 Share Posted June 14, 2015 (edited) I don't know any other vehicle that is as prone to engine threatening problems as the old generation Subarus. I can name about a dozen easy. Really doesn't matter what kind of car it is, any large coolant leak that goes unnoticed or unchecked is going to write a death cerficate for the engine. Subarus are most certainly not an exception. Edited June 14, 2015 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
lstevens76 Posted June 14, 2015 Share Posted June 14, 2015 No car is an exception. Actually some Ford and Honda V6 engines were well known, even more so than Subaru, for blowing head gaskets. Another possibility is the o-rings under the the coolant pipe under the intake. But I am guessing it's a heater hose which has nothing to do with the engine itself and should have been checked/replaced with the swap along with the throttle body hoses. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted June 14, 2015 Share Posted June 14, 2015 No car is an exception. Actually some Ford and Honda V6 engines were well known, even more so than Subaru, for blowing head gaskets. Another possibility is the o-rings under the the coolant pipe under the intake. But I am guessing it's a heater hose which has nothing to do with the engine itself and should have been checked/replaced with the swap along with the throttle body hoses. Even air cooled cars like the Corvair were prone to overheating and blowing head gaskets. Quote Link to comment Share on other sites More sharing options...
ThosL Posted June 14, 2015 Author Share Posted June 14, 2015 The other vehicles I had were V8 GM pick-ups, never had engine problems. As they say an ounce of prevention is worth a pound of cure. Most of the work I have had on the car they haven't done much in the way of preventative maintenance. Quote Link to comment Share on other sites More sharing options...
jp98 Posted June 14, 2015 Share Posted June 14, 2015 The other vehicles I had were V8 GM pick-ups, never had engine problems. As they say an ounce of prevention is worth a pound of cure. Most of the work I have had on the car they haven't done much in the way of preventative maintenance. The GM engines in pickups were prone to head gasket failures. The company that I worked for bought a lot of them and just about all of them had a head gasket failure within 2 years. One problem with new designed engines is that the manufacture doesn't put them on a torture rack of stop and go, start and get hot and then shut them off to repeat it. They hardly ever let the engine cool down and see what the expansion and contractions of the block will do. This is a problem with all of the manufactures. Quote Link to comment Share on other sites More sharing options...
xdeadeye1 Posted June 14, 2015 Share Posted June 14, 2015 2001 Silverado 5.3 v8, No engine problems ever,, 175k miles. (knock on wood) Quote Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted June 15, 2015 Share Posted June 15, 2015 2001 Silverado 5.3 v8, No engine problems ever,, 175k miles. (knock on wood) The long blocks on the LS series where great. Let me know when you get knock sensor codes! Quote Link to comment Share on other sites More sharing options...
ThosL Posted June 15, 2015 Author Share Posted June 15, 2015 I found the thin hose on top of the engine had the leak, very hard to get to unless you had super thin fingers to change it. Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 14, 2015 Author Share Posted September 14, 2015 I was able to do those two hoses myself; another leak has developed from around the water pump which was replaced last fall. I spoke with F and S the Subaru experts locally and they said that is not a do it yourself hose replacement. Apparently the hose comes from around the engine down to the water pump. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted September 14, 2015 Share Posted September 14, 2015 It is indeed a DIY repair. 2 10mm bolts on top of the head and the hose clamps that go to the throttle body and water pump. You will probably have to loosen the dip stick bolt as you have to wiggle the pipe in and out. O. Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 14, 2015 Author Share Posted September 14, 2015 OK, thanks. I will follow up and let you know how it goes as this must be done apparently with the drip, drip drip when driving. Too bad those hoses weren't replaced when the water pump was done. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 14, 2015 Share Posted September 14, 2015 Is the steel line leaking? The elbow hose that's down by the pump is a somewhat common leak point. If it's the steel pipe you have to pull the intake manifold off to get that pipe out. Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 14, 2015 Author Share Posted September 14, 2015 How do I diagnose which it is? I just bought a couple feet of 5/16 rubber fuel line to do the job if it is the rubber line. If it is the rubber line what are the steps to remove and replace it? It looks pretty well hidden. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted September 14, 2015 Share Posted September 14, 2015 download the fsm. It's invaluable. O. Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 14, 2015 Author Share Posted September 14, 2015 I'll go back out there and see if I can see where the leak is coming from. Having had the two hoses over the engine blow out probably the rubber one to the water pump is now going. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 15, 2015 Share Posted September 15, 2015 (edited) Usually pretty easy to tell if its the hose at the pump. It's not hard to get to from underneath. 1 clamp at each end and you can pull it off. Edited September 15, 2015 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 15, 2015 Author Share Posted September 15, 2015 Leak was from the thermostat hose junction; I pulled the thermostat out due to overheating and left the rubber gasket in. Quote Link to comment Share on other sites More sharing options...
xdeadeye1 Posted September 15, 2015 Share Posted September 15, 2015 wut? Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 16, 2015 Author Share Posted September 16, 2015 And by the way the car runs much better without the thermostat; no overheating, leaking is minimal, can drive at 65 without problems. Bubbling in the radiator overflow is still happening though not that bad. Quote Link to comment Share on other sites More sharing options...
