Hi, I have a 2000 Legacy L Station. I just bought it this past January. For some reason about a month ago as I was driving down the Highway doing about 75 mph up a mountain, I noticed that the Temp gauge started to climb and stop just before it got into the red zone. Turning the heater on brought the temp back down to normal. On the other side of the mountain I didn't have any problems with the temp gauge rising again. Until about a week ago.... Now when I'm running at any speeds past 65 the  temp guage will climb. But the moment that I slow down to 65 or under then temp starts to go back to normal. Both fans do come on. And I have noticed that when I come to a stop sometimes that the car sounds/feels like it's bubbling but when I look into the overflow tank there are no bubbles coming out of the hose.
Three things to look at (for  now we will skip the ever fearful headgasket)
1- Radiator cap
2-Thermostat
3- Cooling system leak
How is your coolant level?
Coolant level is full. Overflow tank is at the fill line mark.
But, Is the radiator full?
Another C-villian! We're multiplying on here...
Yes the radiator is full
If the cap is bad it wont draw coolant back int the radiator. It chouldnt be full, should be at the hot or cold line.
 And it's in between the hot and cold lines in the reserve tank
Ok just finished putting on a new Thermostat (from dealership), and Radiator cap (from dealership). Also while I had the car up changed the oil. I'm about to go on a drive and will post the results.
dang - hoping it isn't HGs.
if it overheats again, pull over and, with the engine running,  see if either; 1. there are bubbles coming up thru the coolant in the overflow tank or 2. the overflow bottle is filled vey high or spilling over.  (don't remove the rad cap on a hot engine!)
Edited by 1 Lucky Texan
Well it's still an issue. Was driving on highway doing 75 mph with ac on and it took longer for it to happen but the temp went up to just before red. slowed down to about 60 and temp dropped. No bubbling sound with the new tstat in
Edited by Baslyn
I had the same thing happen with an EA82 wagon. It turned out that the radiator was internally blocked. Try a Radiator flush first before replacing the Rad.
Thinking same thing....the radiator is plugged up. Does the car's heater work really well...as in pumping out really hot air. If not, then it is possible that the previous owner dumped a bunch of radiator stop leak in the system. Result can be blocked radiator, and blocked heater rad unit.
Previous owner may have had a head gasket leak, so dumped something in the cooling system to see if that would help.
Things to think about.
Usually these symptoms are due to a system not holding pressure and the most common cause for not holding pressure is the radiator cap.  Check the area inside the radiator where the inner gasket of the radiator cap seals to make sure there are no gaps or deformities.  Check the rubber on the new cap to make sure it didn't come with a defect.  A new cap should have fixed the issue.
Maybe you still have a bubble in there.
Do you have an infrared thermometer?
You can use that to check the radiator for "cold" spots.
Its kind of tricky to do on these since the fans are in the way. You drive the car until it gets to normal temp, then check the radiator in several places for temperature variation in the core.
Temperature should have a steady decrease from left-right or top-bottom depending on which way the core tubes run. (Horizontal or vertical)
If you find a spot in the core where the temp drops drastically that indicates a clog in the core tubes in that area.
I'm actually suprised no one said to simply get an infrared thermometer and check the temp of the system in general.
Have you had any other symptoms besides the gauge?  It could be that your problem is actually in the temperature sender for the gauge (not sure if that's on the Coolant Temp Sensor or separate on that car).
Read the post above yours.#17
Fairtax was referring to  using it to specifically check the radiator for cold spots to identified a potentially clogged radiator.
What I was referring to is verifying the gauge is actually reporting correctly.  It's always a possibility the problem could be the temp sender unit or the gauge itself and the car isn't overheating at all.  I've only seen that once myself (not on a Subaru) and don't think it's very common, but it's always a possibility.
Guage and computer use the same sender on this year.
Symptoms don't sound like a bad temp sender. That would show up anytime. The OPs problem only happens on the highway.
Yes the heater blows hot like no other car I've ever owned. Also have had no fluid loss. Checked tonight before leaving work. Doesn't look like any damage to new rad cap.
Edited by Baslyn
Also don't know if this is the same problem but for some reason the front passenger side plug wire keeps coming off the plug. Getting a knock sensor code when it comes off. Plug it back in, clear the code and it stays gone until it pops off again. I just changed all plugs and wires about a month ago.
