My '00 OBS - replacing my '96. :)
lstevens76
  • 2 weeks later...
I want to build a Frankenmotor for it, but I want time to do it so I can do it right.  EJ251 Block w/ EJ22 Phase 2 heads, STI Head gaskets, all OEM gaskets otherwise, full valve job, etc....  To do that I need time which is why this EJ22 Phase 2 is going in. :)
And I have a hoist, just fighting one nut.
Edited by lstevens76
So, I learned something.  If you use an 18" Flex Head Ratchet you can get that bottom driver's side bell housing nut from the top!  It's out!  No longer fighting it so all I need to do now is drain the oil (which I should have already done, I know), then pull her out.
I need to swap a few components then put the new one in. :D
The swap is in and it's running like a champ.  AC works, cruise works, etc...  I still need to do the Driver's side Axle + Ball, it's going to need struts soon, and I need to tear the dash apart to replace some burnt out bulbs....  But she runs good. :)
  • 3 weeks later...
Well I found another one, wrecked on the right front and supposedly bent frame.  I'm considering picking it up since it has the leather interior (rare for an Impreza) and factory fogs. :) So this car might be getting a few more upgrades in the near future.
What it has gotten was a new stereo + new front speakers and I have new front struts and brakes I need to put on it.
  • Like 1
