subiphoenix89 Posted June 29, 2015 Share Posted June 29, 2015 93 legacy gushing coolant from bottom of engine replaced t Stat and gasket and water pump gasket still doing it tried stop leak yes I know lazy but anyways still gushing from bottom please tell me if head gasket or block leak. Not much detail but I'm currently angry but please ask for filler info. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 29, 2015 Share Posted June 29, 2015 Did you replace the small elbow hose that goes to the water pump? Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted June 29, 2015 Share Posted June 29, 2015 Get dirty. Climb under there and check while the car is running. (or not if it's a big leak) Either you missed tightening on your thermostat gasket, or it's a failure on that water pump hose or the lower rad hose. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 29, 2015 Share Posted June 29, 2015 yeah, a pressure test and eyes on the area should help - maybe a part is cracked? Quote Link to comment Share on other sites More sharing options...
xdeadeye1 Posted June 29, 2015 Share Posted June 29, 2015 yeah maybe the bypass hose that runs from the T stat housing to a pipe,, is ripped or torn and you cant see it. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted June 29, 2015 Share Posted June 29, 2015 yeah maybe the bypass hose that runs from the T stat housing to a pipe this is my guess. especially since you have replaced almost every thing else in that area. Quote Link to comment Share on other sites More sharing options...
