Fish-N-Fool Posted July 10, 2015 Share Posted July 10, 2015 (edited) Never mind I think I got it figured out. I wasnt checking it with a helper to cycle the pump like i needed to, so it does have power when you first turn the key on, but the pump doesn't work so It just needs a new pump Edited July 10, 2015 by Fish-N-Fool Quote Link to comment Share on other sites More sharing options...
lmdew Posted July 11, 2015 Share Posted July 11, 2015 Get a Subaru Pump! I'd get a used Subaru pump over an aftermarket any day. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 12, 2015 Share Posted July 12, 2015 I am not very familiar with these newer models, however it worth tell you that some Fuel Pumps' Circuits, receives the signal from the Crank position sensor to let the fuel pump work, so it will be stopped / not receiving voltage until the engine moves, either by the Starter motor or by itself. So, I kindly suggest you to re-check the voltage at the Fuel Pump while cranking. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 12, 2015 Share Posted July 12, 2015 Check the pins inside the plug and make sure they aren't corroded or burned. Quote Link to comment Share on other sites More sharing options...
