Speedwagon Posted July 27, 2015 Share Posted July 27, 2015 Which configuration of car and engine did not come with an EGR valve? Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted July 27, 2015 Share Posted July 27, 2015 generally speaking, but not guaranteed true for all, the manual trans ej22s, legacy and imprezas, did NOT have EGR. but you ALWAYS have to double check. i have never heard the question posed this way. usually it is which do have EGR? why do you ask? Quote Link to comment Share on other sites More sharing options...
Speedwagon Posted July 27, 2015 Author Share Posted July 27, 2015 I have a 98 2.5, that has the EGR. But I have a JDM EJ20 turbo to put in the car, which does not have an EGR. The emissions place only checks the sticker under the hood, so if I were to order a new sticker, based on the VIN from a non-EGR 98, they wouldn't care then, and I'd still pass the roller test. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 27, 2015 Share Posted July 27, 2015 That probably works as long as the VIN isn't on the sticker. Or as long as the inspector doesn't check the VIN on the sticker... Quote Link to comment Share on other sites More sharing options...
987687 Posted July 27, 2015 Share Posted July 27, 2015 You're gonna have to use your USDM intake manifold for it to work, which has an EGR valve. Just plumb the intake of the EGR valve to the intake post MAF. I've done this with success on a few DOHC cars. Quote Link to comment Share on other sites More sharing options...
jp98 Posted July 28, 2015 Share Posted July 28, 2015 I don't believe that you can order a new sticker. They are usually specific to the vin number of the vehicle and can't be changed. A lot of people are having problems with cars and trucks swapping in different engines that require older EPA regulations but they need to meet the EPA regulations that were for their vehicle and not the older engine. Quote Link to comment Share on other sites More sharing options...
Speedwagon Posted July 28, 2015 Author Share Posted July 28, 2015 (edited) The vin is not on the sticker, and you can order them based on vin from the dealer. So my plan works, as long as I find a vehicle. And yes, federal regulations require the newer of the engine or vehicle emissions requirements. So it's not really a problem, it's the law. But as long as I can meet the numbers on the rollers, actual equipment, to me, is irrelevant. Also, using the 25d manifold won't work, because the injector size is not large enough for the turbo. Edited July 28, 2015 by Speedwagon Quote Link to comment Share on other sites More sharing options...
Bushwick Posted July 28, 2015 Share Posted July 28, 2015 Can't you just swap in new injectors? Why not just turbo the 2.5L instead? Just sell the 2.0L short block and keep the turbo. Hell, just get turbo exhaust manifolds and run whatever turbo you want. You just need to add an oil return line fitting on the oil pan, an oil feed line, highly advisable oil cooler, and finally a coolant line to feed the turbo then return to the engine. Find an aftermarket FMIC and stuff it behind the bumper or whatever and get a blow-off valve from a factory turbo'd car like VW, Saab, etc.. Spend a few bucks on a custom ECM that's tunable and make a bracket to support the turbo and you are golden. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 29, 2015 Share Posted July 29, 2015 Doing a full turbo swap right? And thus have the turbo ECU and harness. So manifold, wiring, injectors all moot points. If you can order the sticker, order the sticker. Sounds like a $10 fix to me! Quote Link to comment Share on other sites More sharing options...
