bogging acceleration after adding weber
6 replies to this topic
#1 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 27 May 2004 - 12:53 AM
I put a brand new weber on my 83 wagon and then took it for a test drive. it accelerated slower in first gear and didnt have any power at any RPM in 2nd gear. Im wondering if anyone could try to tell me what i might have screwed up when i put the carb on. I was hoping to gain power instead of losing it.
Also the car wont idel until it warms up. I has the electric choke. I conected the origonal hitachi wires to the weber, but the hitachi had two extra wires that went to a triangle shaped piece that actuated some sort of plunger. I couldnt find anywhere those might attach to the weber. That is my only idea on why the idle is bad.
Thanks
David
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 27 May 2004 - 01:19 AM
it sounds like you just need to do some tuning. The weber experts will be able to point you in the right direction.
#3 Flow
Flow
    Eat, Live, Breath Subaru
  • 257 posts
  • Roy
Posted 27 May 2004 - 02:19 AM
I'm definatly no expert, but you might try advancing the timing up to 10 to 12 degrees and then retuning the carb. Also might check to see if there was power to the electric choke or not. Did you buy the redline carb kit (K730 or 731?) that is properly jetted for our application?
#4 84Scoobaroo
84Scoobaroo
    USMB is life!
  • 171 posts
  • Puyallup
Posted 27 May 2004 - 02:26 AM
I'm definatly no expert, but you might try advancing the timing up to 10 to 12 degrees and then retuning the carb. Also might check to see if there was power to the electric choke or not. Did you buy the redline kit (K730 I believe) that is properly jetted for our application?
Also might look into getting an electric fuel pump as well, if you dont have it already. Webers like to have ~3.5psi as opposed to the stock hitachis' 1-2 psi(i think). May need a AFPR depending on the pump. Just hook it inline to the Weber and use the stock pump to feed it.
Webers dont like to be cold, but they can idle no problem when there cold. They just work better when warm ;) . I dont know how the electric chokes work on the webers' as Ive always been fond of pulling the handle to start :) .
Hope this helps,
Jay
#5 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 27 May 2004 - 06:52 AM
Check the drop and rise of the float also.You may recognize this "tool" from granies sewing box, it is a "hem" measurer from walmart apx. $.89!!!
#6 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 27 May 2004 - 04:51 PM
Thanks for the help i'l give them all a try, it is the redline kit from carbs unlimited. Do you guys have any ideas for a better fuel pump i know people were running pumps out of other cars. I set the fuel air screw to what was in the directions. Im actualaly glad that it is problay something to do with the carb because this car is seeming to take forever to get running, and all i need is another problem.
Thanks
David
#7 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,692 posts
  • Portland
Posted 27 May 2004 - 05:09 PM
I would look for vacuum leaks. Your description of it not idleing till warm indicates a potential vacuum leak, or bad adjustment of the idle mixture and speed screws. The stock fuel pumps work fine normally, so I would look elsewhere as long as you are getting fuel. The NAPA fuel filters (under hood) are made by WIX, and are clear so you can see if the filter is full or not.....
