EA82 stiffer spring questions
8 replies to this topic
#1 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 28 May 2004 - 10:36 PM
Has any body tried XT-6 springs on the front of a EA82?
I was thinking of using XT-6 front springs and the Accord springs on the rear of my '87 RX Coupe. I'll chop them down a bit so it doesn't ride too high.
Has anybody tried this? Does anybody know anything about spring rates and stuff for this application? Will it blow my handling if the spring rates are out of wack front to rear?
I'm trying to stiffin up my car (ghetto style) for Rally Cross.
Thanks.
#2 samo
samo
    Boo.
  • 731 posts
  • The Emerald City
Posted 28 May 2004 - 11:20 PM
I am also very interested to know if XT6 springs will work. I already plan on doing the Honda spring mod.
XSNRG - Have you thought about using a set of Honda lowering springs for the rear? You'd wind up at about stock height after it's all said and done and in general, a lowering spring is quite a bit stiffer than a stock one.
#3 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 29 May 2004 - 02:33 AM
hmm thats some thinkin there. I like it.;)
WJM has some idaes/ spring hook ups.
suba styles used coil overs off a mk4 vw
#4 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 29 May 2004 - 08:48 AM
*evil laugh*
Posted Image
Posted Image
#5 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 29 May 2004 - 09:01 AM
Just read over the post again....
For rally cross...the RX springs/struts would be perfect. The dampers are 2x as stiff as other factory stuff, and the spring rates are slightly stiffer. My RX rides wonders better compared to the GL-10 abck in the stock days.
The springs on my GL-10 started off as 400lb front and rear...8 in tall on the front, and 10 rear. Ive cut them (no torch! Portaband!) down to 6 front, and 7 rear. The rear is basically on the bumpstops, and the front hits every big/sharp dip. I need to replace the stock bump stops with something better. Otherwise, with the camber/caster plates up front, the handling is WONDERFUL in the corners. Its the bumpy stuff that really upsets the car and then its not very fun...but its certinly exciting. The Previous set of springs, Pleiades has them on his RX now...was just about perfect. The front were 8 tall, and 250 lb rate. the rear were 10 , and 300 lbs. The only thing i would have changed was to cut 2 inches of the rears...it was too high for me. 3 inches of fender clearance...where as the front had about 3/4 of an inch.
So, id go with a stock RX suspension with some camber plates.
#6 XSNRG
XSNRG
  • 3,657 posts
  • Olympia
Posted 01 June 2004 - 08:28 AM
Does anybody know the stock spring rate on the Accord springs? I'm wondering if they are stiffer or just longer. I assumed that front springs would be stiffer but on the RX the fronts are 157 and the rears are 179, so I'm curious about the Accoud spring rates.
#7 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 01 June 2004 - 09:13 AM
well they are definately stiffer NOT longer. when compared side by side uncompressed they are verry close in lenght.
I do not know the actual spring rate. the coils are visibly thicker.
#8 garner
garner
    Brat Master Flash
  • 689 posts
  • Vilas, NC
Posted 01 June 2004 - 12:40 PM
I've been wondering if Ebay "Ghetto Coilovers" might be an option. If you search ebay for "subaru suspension" you often get a bunch of tuning conpanies selling cheap sleeve overs (like the ground control set up).
Has anybody looked into these as an option on older subarus?
WJM, the portaband rules!!! best tool for that job for sure
garner
#9 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 02 June 2004 - 11:28 PM
ive been wondering on the cheap sleeve coil over idea myself. Seems that it would work.
Portaband is the best tool ever invented....well, on of the best for sure!
