aussysubaru8593 Posted October 31, 2015 Share Posted October 31, 2015 Hi there Recently bought a 1985 1.8 gl Touring wagon sunrasia rims tall roof 225 on clock 350$ One or two problems like the heater busted inside car and fluid all over passenger floor By passed the heater Any hows cant get it started rather starts and stops Had good look and the chike cable is loose Yes goid old choke cable Cant find a pic anywhere even in repair manual of where the darned thing goes Love to see it going again Any one with any ideas id love to hear from u Save my suby Also have a 1993 sportswagon which i am working on Some idiot at a repair shop used a impact rattle gun when removing spark plugs and stuffed the threads i hope helecoils will work Anyone had anyluck with helecoils on a aliminium head Love yhe subys cant wait to see seven mile beach a fishing tod or two and a bbq Thankyou to whoever could help with either question Aussydan Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 5, 2015 Share Posted November 5, 2015 Welcome to the USMB. I'm going to move your thread to the Old Gen forum where it may get some more attention on your specific questions. Quote Link to comment Share on other sites More sharing options...
l75eya Posted November 6, 2015 Share Posted November 6, 2015 Used an impact on the spark plugs LOL wow! Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 6, 2015 Share Posted November 6, 2015 The 1985 Touring Wagon, has the EA82 engine, or the EA71? ... ... The Manual choke was used by Subaru on their EA71 engined Touring Wagons; I kindly suggest you to share some photos of your wagons here, so we could help you better. ... Some idiot at a repair shop used a impact rattle gun when removing spark plugs and stuffed the threads ... Yes, that is Horrible! ... ... If the thread stripping was too Rude, I bet you'll need to send the Heads to a Repair Shop, in order to fill the openings with Aluminium and redo the Threads... Good Luck! ... Kind Regards. Quote Link to comment Share on other sites More sharing options...
l75eya Posted November 7, 2015 Share Posted November 7, 2015 (edited) Rude isn't quite the right word to use there, I think what Jes means to say is if the damage to the threads is too severe, you'll have to have them repaired at a shop. Just a friendly correction jeszek, your English is very good, "rude" just isn't the right adjective for that. :-) Edited November 7, 2015 by l75eya 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 8, 2015 Share Posted November 8, 2015 Correction accepted. Usually I use the same adjectives that we use in Spanish, and some of them has different meanings in English, sorry. I was trying to say if the stripping was done very violently... Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
l75eya Posted November 8, 2015 Share Posted November 8, 2015 Kindest regards to you, too, Jes. I hope all is well. And back on topic to the original poster, I echo the desire for pictures! A stock manual choke ea82, or is it an aftermarket setup? 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 8, 2015 Share Posted November 8, 2015 I only have seen Stock Manual Choke on EA71 engined, third gen Subaru Leone: ...Note the "Manual Choke" Control on the Dashboard: it was a 1.6L (EA71) Gen III Leone DL (Manual Windows)But it had the Optional Wooden Steering Wheel. Quote Link to comment Share on other sites More sharing options...
wagonist Posted November 9, 2015 Share Posted November 9, 2015 (edited) 85 model EA82 had the semi-auto choke here. It's the only model that did. My first subie was an 85 sedan with this type of choke. Because it's so rare, the repair manuals don't cover it. What is meant by "the cable is loose"? The lever you pull on is attached to the cable by a small grub screw underneath. The cable box itself is held on by the round plastic grommet on the front (hidden behind the lever) unwinding off the surround. How many k's on the 93 model? I know someone in Qld who's got a sportswagon they're stripping. He (well his wife) might be interested in getting rid of the engine block (or complete engine). Got to be better than working on a helicoiled spark plug. I'd also worry about it coming loose again... Same guy has a really rusty 85 touring wagon with the manual choke he's stripping. so if your cable is stuffed, I can ask him. Edited November 9, 2015 by wagonist Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 25, 2016 Share Posted January 25, 2016 Found a best Picture of the Choke Lever on an EA82:Any Updates for this thread? Quote Link to comment Share on other sites More sharing options...
subnz Posted January 25, 2016 Share Posted January 25, 2016 (edited) Found a best Picture of the Choke Lever on an EA82: Any Updates for this thread? Exactely the same on the 3rd gen 86 Leone (GL) Ea82 Wagon I had. The choke cable needs to be adjusted / shorted to take up / readjust slack at carb, need to take off aircleaner box to do this. make sure choke butterfly fully open with choke off. Also make sure to check readjust fast idle linkages to throttle butterfly. otherwise when you pull choke car won't run. It should be be running at about 2000rpm at full choke then return to normal idling speed when choke off/fully pushed in. Also found the manual choke far superior to the auto choke on later 88 Leone / GL I had also especially for cold winter starts because of its better adjustibility. Edited January 25, 2016 by subnz Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 25, 2016 Share Posted January 25, 2016 Yes. I shared those Photos here, because seems like the Manual Choke wasn't an Option for the EA82 in USDM, (maybe on the DL lineup?) but I found them on the LADM (Latin American Domestic Market) Specs' Subarus, as well in AUDM, NZDM, JDM, and certain European markets; However, this Manual Choke is more often seen on the EA71 engined, third gen Leones. Kind Regards. Quote Link to comment Share on other sites More sharing options...
